BMW M20 Head Flow Data
  • digger
    • Nov 2005
    • 6199
    This thread is for people to show the data for cylinder head flow and related aspects and hopefully be stickied.
    Those putting data here should mention as much of the following where possible.
    - Casting P/N i.e. 885, 731, 200 etc
    - Brand: BMW, AMC, etc
    - Valve Sizes if not stock: Stock 885 42mm/36mm; Stock 731 40mm/34mm; Stock 200 40mm/34mm
    - Valve Brand if non OEM: E.g Schrick, Supertech, Manley, IE, etc
    - Test Pressure: i.e. 10” H2O, 25”H2 O, 28”H2O
    - Configuration: Bare cylinder head, cylinder head with manifold, etc
    - Shop that did work.
    Some data I have
    Stock 885 vs Alpina 885 vs Metric Mechanic Rally 885 ST valves 42/36
    Bare Cylinder Heads, BMW castings; Test pressure 10” H2O Racetec
    Stock 885 BMW vs Knight engines (TK) Ported 885 AMC casting 45/36 Manley valves
    Bare Cylinder Head; 28" test pressure
    Knight Engines, Adelaide, South Australia. 1,624 likes · 2 talking about this. Tony Knight
    Inlet
    Exhaust
    Stock 885 BMW vs Stock 731 BMW vs Racetec ported BMW 885 standard OEM valves
    BMW castings, Bare Cylinder Head Test pressure 28” H2O
  • digger
    • Nov 2005
    • 6199
    link to Marquis Rexs data
    • e21jps
      • Aug 2011
      • 44
      heres my ones @28" bare head with 10mm radius entry plate
      I also tested it with ITB intake manifold on, also with 10mm radius entry plate
      oem 731 casting, custom stainless valves 36ex 44in, porting done by RHD
      gone for a slightly different approach to TK i tried to concentrate on low and mid lift flow more than top end flow but not sure if its actually better or not.
      This is the actual head fitted to my 293wHp race engine
      Intake bare head
      Intake with inlet manifold
      and exhaust
      I sell ITB's and performance parts www.racehead.com.au
      e21 race car m20 power! 293Whp atmo 2.9
      details here http://e21jps.webs.com
      drive by video http://www.youtube.com/watch?v=kOdPbErYlho
      incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
      incar video http://www.youtube.com/watch?v=aQyvDR-B00A
      drag racing http://www.youtube.com/watch?v=7XmznH6PND4
      • e21jps
        • Aug 2011
        • 44
        some plotted overlays, would be interesting,
        that would give us some nice comparisons of two porting styles and will be interesting to analyze with dyno results later too
        anyone with a printer??.....
        • digger
          • Nov 2005
          • 6199
          lets keep this as a database for DATA only
          • LJ851
            • 7919
            Great idea, where did those theories go? ;)
            I have high hopes for this thread, wish i could contribute some DATAS.
            Lorin
            The M30 is God's engine.
            • bmwmaster81
              • Sep 2012
              • 49
              Here some data which i got today.
              Its an 731 Head with 42mm / 36mm Valves and 3 angled seats. I think Intake flow is better than stock 885 Head.
              By the way does someone know .050 inch duration of stock 325i cam?
              Need to do some calculations.
              • digger
                • Nov 2005
                • 6199
                Valve lift at 0.050" absolute is approx 209*
                i had a test done on old 885 head in 2008, it was an old superflow tested at 10"
                0.200 = 64
                0.300 = 91
                0.400 = 105
                0.500 = 114
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  That's the exact built head I have sitting here w a 272 so it sounds encouraging. I just wish I knew what any of this meant
                  Alice the Time Capsule
                  • bmwmaster81
                    • Sep 2012
                    • 49
                    In the diagramms you can see how much flow goes through a port at a given pressure and valve lift.
                    More flow = more performance.
                    @digger
                    Your stock 325i head numbers are everywhere higher than my optimized 320i head. I hope this is caused by different methods and benches.
                    especially that it flows everywhere better makes me little surprised.
                    Shouldn't my head have some advantages ? eaven at some lifts?
                    It has:
                    -The same valve size like 325i
                    -its ported with really round and good short radious transition
                    -seats have 3 angle cut
                    - valves have back cut
                    -better port angle entering the chamber
                    Maybe flowbench doesn't benefit from this advantages like hopefully real world flow does ;D
                    Smaller ports at some point should cause more velocity at some points and also fill cylinder better ?
                    We will see.....
                    • digger
                      • Nov 2005
                      • 6199
                      why not just flow a stock 885 head on same bench if you want the real answer?
                      • bmwmaster81
                        • Sep 2012
                        • 49
                        its not possible....sadly
                        it is done at a bench 1500km away where i sent the head for machining the seats etc....
