Engine stored for 3 years....
  • Cletonius
    • 2809
    I'm selling it and need to run compression tests.
    Is there anything special I need to do before cranking this over by hand to do the tests? Should I spray anything in the cylinders?
    It was a strong running motor when pulled, I'd like to get the numbers without causing any damage.
    Help?
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
  • Bullhead
    • Sep 2014
    • 532
    I always like to spray just a tad of Marvel Mystery oil in each cylinder if had been setting a while.
    sigpic87 325E The Honey Badger
    • dnguyen1963
      • Nov 2011
      • 2651
      Squirt some regular 15W40 would be just fine before hand-cranking the engine.
      • Cletonius
        • 2809
        Thanks guys. No worries about bearing damage?
        - Josh
        1990 325is
        Need a shift boot?
        • TobyB
          • 5287
          Nope. Pull the plugs, roll it over. The oil's still in there.
          But it's a good idea to roll it over enough to get oil flow, then get
          oil onto the cam. In fact, might grease the cam just for good measure.
          I usually spin it on the starter until it shows good pressure....
          t
          • Cletonius
            • 2809
            Cool, thanks!
            It's on a subframe with no trans or accessories so using the starter isn't really an option. :(
            - Josh
            1990 325is
            Need a shift boot?
            • LJ851
              • 7919
              Originally posted by Cletonius
              Cool, thanks!
              With the plugs out you could drive the crank bolt with an electric drill or impact wrench.
              Lorin
              The M30 is God's engine.
              • BLACKCHARM88
                • Jun 2014
                • 563
                Change the oil, after all those years of sitting the engine accumulated moisture into the oil.
