Are all the Cam Gears the same in the M20s?
  • estoguy
    • May 2013
    • 1087
    Quick question... I still have the original cam gear in my Eta - the pressed metal one. (9/85 build, so not the one that was under recall according to Bentley). It has been fine, but I might be able to pick up a sintered cam gear. Should I even bother? When I did my timing belt job last year, the gear looked perfect.
    Also are all the stock M20 cam gears the same size? I looked at the part number, and it matches several BMWs. Just wanting to be sure.
    Thanks.
    Estoguy
  • crazyman
    • Dec 2010
    • 738
    The stock M20 ones are all the same. Defenitely replace that stamped steel one, they are extremely flimsy and will bend under the slightest amount of pressure.
    85 swartz/metallic 325E
    84 alpine 325E
    85 zinnoberot 318i/R.I.P
    84 Bronzit 318i/sold
    purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
      • 34844
      I would replace it. they are known to fail unexpectedly.
      • estoguy
        • May 2013
        • 1087
        Thanks guys... appreciate the advice.
        Estoguy
        • 101
          • Jul 2011
          • 764
          I'd give the same advice for the auxiliary shaft (oil pump) gear as well - if you have a stamped steel one get a replacement for that one too!
          101
          The E30 collection:
          1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
          1987 325is - Delphin / Black Sport (son #3's)
          1987 325i Convertible - Triple Black
          1989 325iX Coupe - Diamondschwarz / Black Comfort
          1990 325iX Coupe - Sterling Silver / Grey Sport
          1981 Fiat 124 Spider 2000 - Green / Tan
          1998 Volvo V70 GLT - White / Tan
          1998 Volvo S70 T5 manual - White / Taupe
          2001 Ford Windstar - Silver / Grey (parts hauler)
          2006 Lexus GX470 - White / Tan (tow rig)
          • estoguy
            • May 2013
            • 1087
            Which one is that in the diagram? My guess is #9? I believe that one was cast. Just the cam gear was the pressed one.
            Estoguy
            • digger
              • Nov 2005
              • 6196
              yep #9 is the aux shaft gear
