M20 head gasket/ ting belt help
  • kmushu
    • Aug 2014
    • 36
    Hey all; currently halfway through getting the timing belt off and I've run into a conundrum. I can figure out for the life of me how to get the distributor rotor off. I've used a dremel, still too soft for a screwdriver. Any tips?
  • dirtie30
    • Jun 2013
    • 28
    well, I'm sorry, but I don't think this timing belt job is for you.
    Step 1. Have all the proper tools.
    • kmushu
      • Aug 2014
      • 36
      I have the Allen keys, the brass is stripped. Duh.
      • DesertBMW
        • Aug 2011
        • 1043
        you would have to grind off the 3 bolt heads totally down to rotor in order to pull it.
        If previous owner used too much force to tighten the 3 bolts then they would simply strip even with proper allen wrench.
        • bootlegskate
          • Jun 2010
          • 139
          First try buying an ez out from any tool supply store. If that doesn't work, try getting a Dremel and grind a groove in the head of the screw to simulate a flat head screw, then remove with a flat head screw driver.
          DD '03 AW M3
          • Ether-D
            • Sep 2011
            • 2838
            The radiator is out, right? Cause that is soooooooooo totally worth it.
            Originally posted by Andy.B
            I was born on 3/25…
            • Cabriolet
              • 9620
              dude. use a small vice grips. i've removed dozens of rotors this way.
              Much wow
              I hate 4 doors
              • 3vilE30
                • Jan 2013
                • 344
                THIS ^ since you have everything apart
                I used an extractor set cause I had no room with the radiator still on.
                • dyasko
                  • Sep 2013
                  • 40
                  I've hammered a torx bit into stripped allen heads on the rotor before and that worked
                  • kmushu
                    • Aug 2014
                    • 36
                    Appreciate it everyone. Had vise grips, but so shitty that they fell apart... So project is shelved until I can get some good ass tools
                    • SmokeE30
                      • 1730
                      Good tools are always helpful but I know you can bust the rotor apart and remove the bolts pretty easily with pliers once you have more room. Rotors are a wear item most people could use replaced anyway.
                      Shawn @ Bimmerbuddies
                      Bimmerbuddies LLC
                      717-388-1256
                      2971a Roundtop Rd, Middletown PA 17057
                      bimmerbuddiesllc@gmail.com
