Miller Maf + war on my 2.7 or not
  • HarteB
    • Sep 2014
    • 47
    Searched the forum for a while because I heard alot about this setup (good and bad things ) .. So I am wondering this is worth shipping to europe
    My 2.7 stroker is currently running 1.1 motronic 173 ecu with modified alpina 2.7 setup .. m52b28 injectors, e38 735i AFM and bigger trottle valve
    What would be my gain .. hp/torque wise .. with my current setup it produces 206hp and 268 nm of torque .. she pulls good from 1500rpm onwards to become really stron from 3500rpm to 6900rpm
    Thx
    straight roads are for fast cars, corners are for fast drivers
    1982 e21 323i rs Hartge
    1989 e30 325i convertible
    1994 e36 m3
  • goldenbb
    • Jun 2013
    • 208
    From what I have read for just the MAF, ZERO horsepower gain, better throttle response. Adding the WAR chip is the question.
    '90 zinno 325iS
    • cdeason
      • Nov 2011
      • 88
      Being in Belgium
      I would go with the MAXX Alpha-N setup, you have a much larger user base and support group and a very good bang for the euro
      • bbs_s52
        • Mar 2012
        • 110
        Driven one with it. Not worth the money imo
        • digger
          • Nov 2005
          • 6128
          i cant see that MAXX alpha N piggback being worth it as it doesnt seem to do ignition timing leave it to the S14 guys
          i would think there are some gains to be had from the WAR but dont know exactly and nobody will tell you definitively
            • 34839
            how about VEMS?
            the war chip is problematic. it does work, but not always perfectly and if you have issues support will be very difficult.
            I second Digger's comment on the Alpha-N setup. Piggybacks that can't control ignition timing are a waste of time.
            • HarteB
              • Sep 2014
              • 47
              Ok .. i'll keep it as is then .. she run smooth and fine with my current setup .. don't want to throw more money in without being sure it will be an improvement .. thx for the input guys 👍
              1994 e36 m3
