overheating while idling, normal while driving
  • ac3
    • Jan 2011
    • 121
    My car runs hot and has overheated a few times while idling, once while stuck in traffic... But driving above 30/40 mph the temp drops back to normal. Is this a bad thermostat issue?
  • jbe21
    • Oct 2014
    • 33
    could be a bad water pump. does the temp drop if you rev the engine for a bit?
    my e21 build thread clickey
    • 3vilE30
      • Jan 2013
      • 344
      You need a new fan clutch.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Newspaper fan clutch test time.
        • TobyB
          • 5298
          Could be a lazy t- stat.
          Most likely lazy fan, though.
          Less likely (not impossible) water pump.
          t
          • xdavesmithx
            • Nov 2013
            • 33
            test the fan clutch, as replacing it is a much easier job than a water pump. if that tests fine, try revving the motor a little while you're sitting still and see if the temperature goes down
