415 Injectors and Tune
  • Klug
    • Sep 2011
    • 804
    Is anyone running a tune/chip on their M20 after upgrading to 415's? I notice a little bit of hesitation when starting about every 5th time or so and I just recently got a weird misfiring issue after running them without a tune for about 6 months now.
    Trying to narrow it down after I took everything apart and this is the only thing that I am suspicious about.
    Thanks
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
  • Klug
    • Sep 2011
    • 804
    Still curious about this- can't seem to find any solid information.
    Misfiring was solved with new O2 sensor and seafoaming. Now everything runs great- overall major improvement with the 415's but I still have that issue starting up every few times.
    If it is necessary to run a recommended chip or tune for these- someone chime in.
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '67 Pontiac LeMans
    • packratbimmer
      • Dec 2009
      • 1335
      Not sure about the 415 injectors, but I bought a set of Gen III injectors (4-pintle) from eBay and my car ran very rich on the stock chip. I ended up installing the stock injectors freshly cleaned by MEPEH and the car ran great again.
      The idle was extremely rough after the ECU had lost memory (Batt. disconnect) and trimmed out a bit after some run time. The car ran fine on the interstate, but felt rich around town. I felt like I was on an old motorcycle and had to blip the throttle to keep the fuel burned off.
      • mr2peak
        • 2388
        You will run rich without a tune, it's definitely a good idea.
        Drive it hard. Maintain it well.
        A Topless Memorandum
        • digger
          • Nov 2005
          • 6178
          its always better to get a chip that was made for the injectors you are using
