SETA DME ECU Performance Chips?
  • pulsejakob
    • Oct 2014
    • 15
    So I was surfing the web and trying to figure out if someone makes a chip for the 154 DME but I can't find a straight answer! and suggestions?
  • reelizmpro
    • 9546
    No, they didn't. That may have changed since 98 when I stopped fooling around with them but I doubt it. Afterall, SuperETA's were only made one year and most go with a 325I dme after upgrading to 325I spec.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • pulsejakob
      • Oct 2014
      • 15
      and the easiest 325i upgrade would be the 325i head, intake mani and DME?
        • 37833
        Agreed. Most people just make it a 2.7i.
        The Super Eta comes with the same head casting as the 2.5L engines. You can either swap out the valve springs and cam or change the head all together for an i head. You will also need the ECU, injectors, fuel pressure regulator, air flow meter, intake manifold, throttle body, TPS, and intake boot.
        Grover Beach, California
        BimmerHeads.com
