Lost oil pressure
  • Ide30
    • Dec 2014
    • 17
    Lost oil pressure
    Driving on the freeway yesterday, the engine became noisy as quick as a light switch and the oil pressure light came on. Pulled over immediately.
    Seems like the oil pump has failed. I did a little searching and not much on the topic. I plan to connect an oil pressure gauge.
    I am looking for advice and words of wisdom... What are the chances I did damage to the engine?
  • dnguyen1963
    • Nov 2011
    • 2651
    If you pulled over immediately then chances are your engine is okay. The warning light comes on way before a catastrophic event can happen to your engine.
    • EyExR
      • Jan 2011
      • 959
      Have you checked your oil level just in case?
      I would replace the oil pump and see how it goes. I'd worry a bit about the noise though. Metal on metal for just a moment is not good. But replacing a pump is a heck of a lot easier than rebuilding the engine. So I'd try that first. I would by no means run the engine again at all until you know you're going to get oil pressure.
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • TobyB
        • 5288
        Should be fine. I would NOT try to restart it, though-
        unless you simply ran out of oil...
        Get the oil pump drive fixed, then prime it, and THEN try checking pressure!
        t
        conservatively.
