m20b25 blue smoke now 1252 code
  • blownm20
    • Jun 2012
    • 39
    The car started up normal then when I put it in gear and started moving it started a heavy misfire and puffed out blue smoke immediately with a heavy gasoline smell. I'm going to do a leakdown test to get some idea of what's going on. Has anyone ever experienced this?
  • catech11
    • Feb 2014
    • 83
    blue smoke means your burning oil, there are many posts about this. Could be rings or leaky valve stem seals
    • blownm20
      • Jun 2012
      • 39
      Turned out to be a headgasket. I know blue smoke is oil. I was more curious about the gas smell.. my only theory is the motor was not getting enough compression to burn all the fuel.
      • digger
        • Nov 2005
        • 6171
        yeah probably unburnt fuel due to missfire
        • blownm20
          • Jun 2012
          • 39
          Now I'm getting a 1252 code. Injector #2. The car is an 87is no c191 connector for the injector harrness. Can it really be as simple as clogged or faulty injectors? All the connectors are fine. Compression is <10% off. Brand new bosche sparkplugs, cap rotor, new 8mm wires.
