Methanol injection on a na m20
  • Bimmer_man
    • Jan 2013
    • 1477
    So I've been thinking on methanol injection on my white ix. It will be running a high compression motor. I was wondering if I where running 91 octane on a 13:1 compression motor with methanol would my car still run well or would it still need 93?
    I don't want to run 93 or e85 because it's not a readily available fuel.
    If you have experience with this please let me know.
    I have my reasons for running 13:1 instead of 11:1.
    Float like a cadillac sting like a Bimmer!:)
  • brody
    • Jul 2009
    • 334
    Depends on your cam. You can have a 15:1 engine and run 87 if you have the "right" cam to do so.
    • Bimmer_man
      • Jan 2013
      • 1477
      The cam will be a 292 roller cam.
      • digger
        • Nov 2005
        • 6188
        if you are talking about spraying then i doubt it is worth it on a NA car, the gains over the base fuel without spray will be significantly less than what you get with FI, might aswell build it for whatever fuel you have access to
        • TheTacoMan
          • Nov 2011
          • 2308
          One of the main reason turbo car benefit is that the engine is being fed air that is not ambient air temperature. If you go with a high compression motor meth would help if you get bad fuel to protect your motor from detonation, however a more variable controller for the meth might be need to regulate the flow of meth for an N/a application.
