Overheating Stroker m20 -solved-
  • Bmwb
    • Jan 2013
    • 196
    i had a 2.9 stroker do this to me endded up to be the smallest crack in the radiator which i found before i sold the car , changed everything also got a lower degree thermostat , also a plugged heater core compressed air is your best friend! , blow that shit out
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
    • efficient
      • Feb 2012
      • 3312
      Prime the heater with coolant and bleed it with the car elevated.
      • downforce22
        • Aug 2009
        • 3193
        To bring some closure to this issue, I replaced the thermostat with an 80 C new one, changed the pump to ensure it wasn't an issue, flushed the coolant and purged it with compressed air to blow out any sediment or blockages.
        I refilled the system and made sure to fill it with the bleeder open. I filled the expansion tank to the top, then started the car. I kept filling the system until the bleeder was flowing coolant out the top before I closed it. Then I closed the expansion tank to ensure air would not get into the system. I made sure the heater was all the way on hot, and turned the air on full blast and waited for the car to get up to temperature. Then I proceeded to continue bleeding the bleed valve while revving the engine to flow more coolant through the system faster.
        Heat started coming and the car now idles and runs great at about 190 F. Bottom line I think I had an air lock in the system that was compressing while the pump was pumping. I am not sure what originally caused the issue, potentially a blockage, but now I know it is no longer blocked and the t-stat is new.
