Timing belt kit advice. Ebay or ECS
  • tonyloban
    • Oct 2013
    • 254
    Going to do my timing belt. I'm also going to be doing a valve adjustment, so any and all advice is welcome. Any advice on what kit to buy?
    The ebay kit doesn't come with a tensioner bolt, only spring. No idea what that's for or if it's even necessary to replace. The ECS kit doesn't come with a crankshaft seal or a valve cover gasket.
    EBAY $102:
    http://www.ebay.com/itm/8pc-Timing-B...969a41&vxp=mtr
    ESC Tuning $136:
    http://www.ecstuning.com/News/BMW_E3...KITS/ES260767/
    My Photography - http://www.flickr.com/photos/106236166@N06/ - My Photography
  • Hooffenstein HD
    • Nov 2012
    • 1388
    I'd go with the eBay kit but if it comes with the pictured tensioner I would file a claim and get some money back. The listing says INA tensioner but the one in the picture is garbage and should be avoided at all costs.
    • tonyloban
      • Oct 2013
      • 254
      • tonyloban
        • Oct 2013
        • 254
        Well I wouldn't want to put that on if it's garbage. On pelican parts, their INA tensioner looks the same. What is the one in the picture? What's the difference?
        • Hooffenstein HD
          • Nov 2012
          • 1388
          • tonyloban
            • Oct 2013
            • 254
            I see now. Thanks! What about the missing tensioner bolt. Is that a problem?
            • Klug
              • Sep 2011
              • 804
              You should replace the bolt and spring while you are in there. I always feel that when replacing a timing belt- to replace everything with new parts.
              You don't want anything to fail.
              555Garage - Kingston, PA
              '13 BMW e70 X5 35d
              '95 BMW e34 525i
              '92 BMW e30 325i S52 Vert (Quade the Vert)
              '92 Range Rover Classic
              '90 Range Rover Classic
              '89 BMW e30 325i Coupe (The DIRTY30)
              '81 VW MK1 Rabbit Caddy Diesel
              '76 Honda CB550K Cafe/Brat
              '67 Pontiac LeMans
              '24 Model T Depot Hack
              ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
              • digger
                • Nov 2005
                • 6216
                i would not use a cheap tensioner, i go for the genuine one.
                • tonyloban
                  • Oct 2013
                  • 254
                  Oh definitely. I didn't even know they have different ones until now. I ordered the parts off ecs and built my own kit.
                  • digger
                    • Nov 2005
                    • 6216
                    i also build my own kits especially when there are critical parts involved otherwise it can be a false economy
                    • estoguy
                      • May 2013
                      • 1087
                      Get a Conti belt/tensioner kit.
                      Estoguy
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Whatever water pump you get, make sure it doesn't have either a plastic impeller or a stamped steel one. You want a cast one. The others are know to fail.
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          IIRC the Geba branded WPs have cast impellers and the Graf branded ones have tack-welded stamped steel.
                          Originally posted by kronus
