Engine cranks SUPER fast, stumbles to life.
  • kwseattle
    • Nov 2013
    • 105
    Hey guys,
    So I recently had my battery replaced because one of the cells wouldn't hold a charge on my old one. It would drop down below 12v after less than a day. Before replacing the battery, the engine cranked at a comfortable sounding speed, and always fired really nicely (assuming the battery wasn't dead, which was often).
    Now that I've got a fresh battery though, whenever I go to start my engine it cranks extremely fast and sounds like it's struggling to fire. It always starts, it just doesn't sound right.
    Any ideas? I'm not sure if there's a voltage regulator somewhere on the way to the starter that prevents this.
    Alpinweiss II 88 325is | M20 | 5 Lug Conversion
    Kyle
  • TobyB
    • 5298
    Hmm- the only thing that pops to mind here is low compression...
    ...and that wouldn't be from a new battery!
    t
    • EatsHondas
      • Sep 2012
      • 404
      I'm with Toby. It should only crank faster than normal if the compression is lower than expected (loose/no spark plugs, extreme engine wear, super tight valve lash, shredded head gasket, etc).
      1989 325i Lachssilber Sedan
      5-Speed Swapped
      M30B35 Swapped
      MegaSquirt MS3X
      1987 325i Lachssilber Sedan
      260k OEM Automatic Daily Baby
      • yodman
        • Jan 2014
        • 76
        Oddly enough I have a similar issue. My engine does have about 260k on the bottom end, but the head and gasket are 50k old. Plugs are brand new.
        Other times it will crank at a normal speed though. It's really weird. I feel like it's a fuel issue since I smell fuel in the bay after this happens.
        1989 635csi - Betty White - 5-Speed, 120k, AWII over Natur Nappa
