M20 sounds awful after timing belt change
  • boogle2
    • Dec 2014
    • 115
    Did the timing belt on my 88 325ix, and now it is making this horrible noise. Uploaded a video to youtube, hopefully the metallic ticking sound can be heard.
    It changes with revs, and sounds like its coming from the a/c / water pump area.
    Other things I changed while I was doing timing belt:
    - tensioner
    - water pump
    - thermostat and housing
    - rotor and distributor cap
    - all v belts
    It sounds terrible and I have no idea what it could be. Please help!
    Thanks,
    Rob
    2011 335i xDrive Msport - sold
    2002 M5
    '88 325ix turbo build :D
  • e30onBBSs
    • Dec 2014
    • 1347
    It sounds like your fan is hitting something. Would make sense if it changed with rmp too! make sure you have it the right way
    BMW tech
    Umass Amherst
    05 wrx sti
    • digger
      • Nov 2005
      • 6199
      yeah fan hitting shroud or radiator?
      • boogle2
        • Dec 2014
        • 115
        Definitely not the fan. I can spin the fan by hand and no interference, and also the noise stops when I stop the car and the fan takes a few seconds to spin down.
        2002 M5
        • audiquattrot
          • May 2008
          • 3836
          Did u install the spark plug wires in the correct firing order on the distributor cap?
          www.instagram.com/snwmble
          #snwmble
          Current:
          '05 BMW M3 - Silver Grey/Imola Red
          '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
          '15 Mini Countryman - Blazing Red/Carbon Black
          Past:
          '01 Audi Allroad - Light Silver/Platinum Saber Black
          '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
          '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
          '90 BMW 325i - Schwarz/Tan sport *Sold*
          '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
          • long tall eta
            • Jul 2010
            • 1536
            check for rub marks on the rad fins.
            • boogle2
              • Dec 2014
              • 115
              Thanks for the help guys. Turned out that two bolts on the water pump pulley came loose and it was rattling back and forth with every revolution.
              Fixed it and it now purrs like the m20 tractor kittens do! Thanks.
              2002 M5
              • Cabriolet
                • 9620
                i had the same thing happen on a guys car i did a timing belt water pump job for. i've had to loctite them in before.
                Much wow
                I hate 4 doors
                • boogle2
                  • Dec 2014
                  • 115
                  Yeah I was a bit shocked they came loose. I was worried I dropped a socket in the water pump or something haha
                  2002 M5
                  • audiquattrot
                    • May 2008
                    • 3836
                    Ahhh that happened to me after I did the timing belt on my old Audi
                    #snwmble
                    Current:
                    Past:
                    • boogle2
                      • Dec 2014
                      • 115
                      Which happened... The loose bolts or the left over socket?
                      2002 M5
                      • audiquattrot
                        • May 2008
                        • 3836
                        Loose bolts on the pulley
                        #snwmble
                        Current:
                        Past:
