Timing Belt Snapped.
  • tonyloban
    • Oct 2013
    • 254
    So my belt snapped. I was rolling about 5mph when it snapped. Right before it happend, I was about to gas to speed up but as soon as I touched the gas, I heard a faint click and the car died instantly and wouldn't start after that.
    I had someone come over and check it out and confirm that it's the timing belt because I don't know too much about working on cars. Learning as I'm going.
    So, if there's a chance that nothing was broken besides the belt (is that even possible or am I indefinitely screwed?) how would I go about knowing? I'm ready to order a huge pack of a timing belt kit which I already had ordered but went on back order (lucky me).
    I've heard compression test but I need to replace the timing belt for that. What else before that can I do to check before I waste my time changing a bunch of new parts.
    My Photography - http://www.flickr.com/photos/106236166@N06/ - My Photography
  • Mr. Tasty
    • Jul 2011
    • 3421
    Bent/broken valves is pretty much every case of snapped timing belt. Compression test won't work with broken valves
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • tonyloban
      • Oct 2013
      • 254
      How do I check the valves?
      • PumpdUpKicks
        • Nov 2012
        • 140
        Removing valve cover and rocker arms
        • Cabriolet
          • 9620
          100% sure bent valves and 90% sure you also damaged 2+ valve guides.
          you will need to pull the head off and have it rebuilt or get a good used one and resurface it. either way you are out ~$500-2k depending on if you do the job or have a shop do it.
          Much wow
          I hate 4 doors
          • tonyloban
            • Oct 2013
            • 254
            So unless I rebuild, there's no use in replacing the timing belt + other stuff like wp and therm?
            • Cabriolet
              • 9620
              if you replace the timing belt and water pump, the car wont run. until you change/fix the head. i've rebuilt many of these engines. in the 10 years of driving these cars, 0 of the heads with snapped timing belts could be fixed without taking off the head.
              the amount of force your engine makes at just idle is would astonish you. it will bend more than a valve
              Much wow
              I hate 4 doors
              • tonyloban
                • Oct 2013
                • 254
                Dang. Thanks for the info
                • Madhatter
                  • Oct 2004
                  • 966
                  I see many of these in your future.
                  Just a little project im working on
                  - http://www.lse30.com -
                  • tonyloban
                    • Oct 2013
                    • 254
                    Lol. I'm in college and engaged. This might mean just sell which I REALLY don't want to :/
                    Decisions decisions
                    • redlightpete
                      • Mar 2012
                      • 266
                      This would be a good time to arrange a back-up car. It makes older BMW ownership a lot more affordable and less stressful. A used head swap isn't that bad a job if you don't have to get it running by the end of the weekend. A well sorted e30 is worth it, so don't give up.
                      • SkiFree
                        • Jun 2011
                        • 2766
                        The problem is timing belts on these cars just don't "break" unless they've been neglected service-wise. What I'm saying is there is nothing inherently "weak" about the design, if you're unsure of the last timing belt job it just needs to be done.
                        ADAMS Autosport
                        • tonyloban
                          • Oct 2013
                          • 254
                          I know that. I had the parts ordered and they went on back order. I was getting ready to do it. Just got very very unlucky.
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Bummer. Well, I wish you the best. You'll have a decent piece of mind once you've gone through the head though.
                            ADAMS Autosport
                            • EatsHondas
                              • Sep 2012
                              • 404
                              Same thing happened to me. New (to me) head and it ran great for a few thousand miles. Then rod knock. Don't know how common it is for bottom end problems to follow a broken timing belt, but it happened to me.
                              1989 325i Lachssilber Sedan
                              5-Speed Swapped
                              M30B35 Swapped
                              MegaSquirt MS3X
                              1987 325i Lachssilber Sedan
                              260k OEM Automatic Daily Baby
