Question about the belts
  • e30onBBSs
    • Dec 2014
    • 1347
    I'm waiting for parts in the mail, and before I do the timing belt which is in there I want to know about the AC and water pump belt and the other one up front. Should I replace those? Can I reuse them? Do they have tensioners?
    BMW tech
    Umass Amherst
    05 wrx sti
  • 101
    • Jul 2011
    • 764
    Inspect them for wear. A worn belt will feel hardened, may have cracking on the inner surface or be "glazed" from wear against the pulleys.
    If they look OK, I'd reuse them. But they are only a few bucks each if you want the peace of mind.
    There are no tensioner pulleys on any of the three belts. The belts are tensioned by moving each respective accessory (A/C compressor, alternator, power steering pump) in their adjustable brackets.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • e30onBBSs
      • Dec 2014
      • 1347
      Thanks for the info! So to Remove the belts I have to loosen the respective accessories?
      BMW tech
      Umass Amherst
      05 wrx sti
      • 101
        • Jul 2011
        • 764
        ^^^ correct.
        101
        The E30 collection:
        • estoguy
          • May 2013
          • 1087
          Honestly, if you're already doing the timing belt, replace them. You gotta take them off anyway and they are cheap.
          Between my first and second timing belt change was 18 months. Since I DD my car, doing the v-belts is cheap insurance. I keep the old one in the car for emergencies.
          Estoguy
          • e30onBBSs
            • Dec 2014
            • 1347
            My ac is broken and my PS is being deleted all I need is water pump belt?
            BMW tech
            Umass Amherst
            05 wrx sti
            • TobyB
              • 5256
              Yarp.
              Well, that and the belt that holds up your pants. You do wear pants, right?
              t
              • 15Michaeljoseph
                • Aug 2013
                • 1693
                Originally posted by TobyB
                Yarp.
                t
                +1 you might also keep a belt on hand to 'secure' any 'precious cargo' from moving around or making noise in the trunk.... just a thought.
                --Mike
                (OO=[][]=OO) For Life
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  Hahaha yea I wear pants often =) I have some family jewels that are valuable..
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • mrob
                    • Sep 2016
                    • 21
                    I like to accessorize
                    I'm wrestling with the power steering pump belt. Does anyone know if #11 is the pivot bolt, ie, the only bolt that absolutely has to be loosened before #13 (tension bolt) should be turned? Thanks.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      #11 will pivot as you tighten the belt but somwill the pump itself so you have to loosen more than just that one. 15 is obvious but worth mentioning and I think 7.
                      Alice the Time Capsule
                      • mrob
                        • Sep 2016
                        • 21
                        Thanks, Jeff. I just saw your reply. Yes, I ended up needing to loosen 3 or 4 nuts in addition to the one on the tension bolt in order for the pump to move. If I hadn't loosened them first, the bracket would probably have become stripped or bent.
                        Now I'm taking on the A/C compressor. It *seems* much simpler: one nut in addition to the one on the tension bolt.
