External fuel pump and no transfer pump?
  • afterglow
    • May 2014
    • 15
    I have an 87 320i (Japan version) which has an external fuel pump. The pump is starting to die so I was planning to install a Walbro in place of the in-tank transfer pump and get rid of the external pump. It turns out that my car doesn't have a transfer pump:
    All this time I thought an external pump automatically means an in-tank transfer pump as well. Guess not.
    What's my best plan of attack considering I'm planning on swapping in an M30B35 soon? The easiest way seems to be to swap out the external pump but I'm wondering if it'll be okay without the transfer pump. There doesn't seem to be an easy way to install an internal pump.
  • 101
    • Jul 2011
    • 764
    That sure looks like an internal pump to me.
    In your pictures you've pulled out the sending unit (three wire plug). Now disconnect those hoses and the two wire plug and turn the assembly about 1/8 turn and pull it out of the tank and see what it is. I'm not an expert on Japanese versions, but my internal pump on my late model looks exactly like that.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • Andy.B
      • Sep 2011
      • 1650
      Yeah, the piece the fuel level sender bolts into IS the low pressure lift pump.
      • reelizmpro
        • 9559
        Pull the whole unit out, not just the level sender.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • pandaboo911
          • 2070
          You have 2 hoses going in. Feed and return. If it were a late model high pressure pump there'd only be one hose.
          Twist the whole thing, get a screw driver one of the tabs and smack it to break it loose. I don't recall if you twist clockwise or counter clockwise
          • vpilarrt
            • Jun 2006
            • 2096
            Late model US 318is has 2 lines. Return dumps right onto the top of the pump.
            • TobyB
              • 5298
              Yeah, unscrew the whole 'sender' unit and see what you find.
              and put some sho3s on!
              hee
              t
