M20 Power hits a wall at 4k rpm exactly
  • nerdydorkus
    • Feb 2012
    • 132
    Hi guys,
    I tried searching but couldn't find an answer. I have a M20 swapped 2002 and it drive around great. But anywhere above 1/4 throttle going up the rpm the range the car just hits a wall at 4k and doesn't accelerate past that. If it is less than 1/4 throttle, it goes all the way to redline cleanly.
    CPS? AFM? My AFM is mounted sideways, hopefully that doesn't affect anything.
  • ak-
    • 12422
    See if the CPS is loose where it bolts onto its little bracket. Happened to me.
    1991 325iS turbo
    • ForcedFirebird
      • Feb 2007
      • 8300
      Yup, first check the gap on the sensor to crank wheel. Loosen the 13mm bolts on the bracket and adjust it a little.
      Next thing I would check is the AFM. They tend to get dead spots on the wiper track and when you open throttle slowly, it may not be "snapping" open that far.
      john@m20guru.com
      Links:
      • LJ851
        • 7919
        CPS, and don't put a cheap ass aftermarket one on there either. BMW or OEM only.
        Lorin
        The M30 is God's engine.
        • nerdydorkus
          • Feb 2012
          • 132
          Thanks, nice to see you're all at the same consensus. What is the gap on the CPS? or is it even adjustable?
          • ForcedFirebird
            • Feb 2007
            • 8300
            Yes. The bracket has wiggle room where it's bolted to the block.
            john@m20guru.com
            Links:
            • packratbimmer
              • Dec 2009
              • 1335
              Had a similar problem and it ended up being fuel delivery. A new fuel pump solved it.
