Greetings, smart people on the internet with answers
Just like the title says, the rpms on my 325e start at a perfectly smooth 700ish rpm idle at start up to a 1300-ish idle at operating temperature in park and neutral. Pretty constant 750-800 in drive or reverse (which is significantly higher than it used to be). Runs pretty well (I hadn't driven it through the winter, so i'm not 100% confident in comparing it to as I remember).
Trying to sort this out I've done everything:
*Have checked for vacuum leaks: Nada. All new hoses, all new gaskets on intake manifold, throttle body, cold start valve, valve cover, o-rings on tube of death, brake booster o-ring, charcoal canister, etc. Everything. I've checked and rechecked and rechecked because I was really hoping this would be the issue. Nope.
New coolant temp. sensor -- checked prior to and after install: working.
New coolant temp. switch -- checked prior to and after intall: working.
Cleaned ICV // Swapped out ICV with known operating one. Neither solved my issue. Both ICV's have the adjustment screw all the way in -- that produces my 750 rpm. Prior to ripping the car apart looking for my vacuum leak that originally lead me to replace everything that could leak, I never had to set that screw all the way in. Unplug at idle produces rev up, then cut out, rev up, cut out as has been described in other posts. *How can I be sure the ICV is getting the correct signals from ICM?
Checked MAF using 9-volt battery test: operating fine (was super glad I didn't have to play with anything in there)
Swapped out ICM with like 9 other green ones ones I've picked up from junkyards: no luck. Tested every connection at the harness end of ICM as per Bentley/what I've seen on the internet. Everything is fine; hot, cold, everything good.
Did every check I could think of pin in/pin out at ECU. Everything seems fine.
Did the Bentley check on the O2...got continuity as Bentley says I should (I'm not really sure what that proves, though).
Checked and adjusted throttle, checked with feeler gauges for close. All good. Checked TPS -- continuity at close, none at open, continuity at WOT at the other pins.
And on and on. If there's a potential solution for this problem on the interwebz and someone put it on a forum, I've read it and tried it.
I know a lot of you will say just to let it go...and if it were a manual I would. However, I have the dreaded automatic and have already put a used one in after my inspection mechanic revved the crap out of it in park after driving it and burned the clutches. I'm worried my high idle (it shoots RIGHT up once you put it in park or neutral) is going to cause tranny failure.
I've checked more stuff than I've mentioned, but I'm unable to recall right now. I've been thorough about this. Not trying to waste anyone's time on their millionth high idle thread.
Things I've just happened to notice: pulling oil dipstick makes car run like crap. Pulling oil filler cap at temperature makes car idle perfectly. I don't even comprehend that...hopefully someone will. Pretty strong gasoline odor from cap (again, this is subjective...I don't really know if it's running rich or not).
Also, after getting to op temp and shutting off engine (for coolant bleeding purposes) I noticed that when car starts, temp. gauge is nearly 3/4 and quickly came down as fan cooled the engine. At 3/4 it had a nice 750 rpm idle for a split second and then shot up as the temp. gauge got to 1/2.
I'm not sure what to make of either of these.
Wtf is wrong with this car? It's driving me CRAZY that I can't figure it out.
Ideas? Things to check? Anyone else have this problem?
Thanks.
Thanks.
