Higher temp = Higher idle -- running out of things to check
  • betsy325e
    • Jun 2015
    • 81
    Update:
    Replaced faulty charcoal canister non-return valve. Still doing the same fucking thing but about 300 rpm lower at operating temperature with the ICV screw all the way in.
    HELP.
    • betsy325e
      • Jun 2015
      • 81
      Update:
      1. Went full out and ripped the intake manifold off looking for leaks/check for a crack in the manifold. Nada. Did a cheapo pipe smoke test. Nada. I am thoroughly convinced this is not a vacuum leak issue.
      2. I spliced in a normal blue connector without a resistor in it to the coolant temp. sensor. Now my ohms at the sensor itself and the idle control module are the same. Did not resolve the high idle.
      3. Removed the black housing on the two prong connector for the ICV hoping I'd find something frigged up in there. No such luck: everything nice, clean, and snuggles.
      4. Connected up ICV with a cheapo ammeter in the loop. Blew fuse rated for 300 mA...so I think she's getting the required 400-500mA variation haha. Time to upgrade ammeter and test again.
      5. Let's say I get the ammeter hooked up and check it and the reading isn't in spec of between 400-500 mA. Does that mean the ICM is fucked, or the ICV? I don't think this is going to be the issue because I've had 3 different ICMs in there and an equal number ICVs at this point.
      *I should note that I cleaned the frig out of all my ICVs. I have seen on some high idle threads that people have done this and that they suspect they somehow ruined their ICV. Is that because people are mistakenly conflating correlation with causation, or does that actually happen? If it does happen, what physically happens that frigs up the ICV?
      Thanks
      • betsy325e
        • Jun 2015
        • 81
        Update:
        Ran car with brake booster line from manifold disconnected and plugged at manifold: No change in idle.
        Retested every pin-in/pin-out on ICM that I could find. Corroded terminal not sending 12 DCV from park/neutral switch. Fixed. No change in idle speed.
        ICV has screw all the way in. Barely holds it down to 1500 rpm at operating temperature. I read somewhere that almost no air should be bypassing ICV with the screw all the way in. However,
        I connected 9-volt battery to ICV with car running. Immediately was able to stall car.
        Anyone got a clue wtf that means?
        • betsy325e
          • Jun 2015
          • 81
          Also: got new ammeter and tested ICV.
          1. Was getting a basically constant 480 mA through the ICV far as I could tell. Bentley says it's supposed to fluctuate. I don't know by how much.
          2. Turning the idle adjust screw from all the way in to all the way out resulted in dropping it down to just 470 mA.
          Anyone? I'm just talking to myself here. Even if you can't help me, say hi. Maybe a joke? Maybe a cute anecdote?
          xoxoxoxoxox
          • tomstin
            • Mar 2015
            • 570
            Did you ever get to the bottom of this? I'm having a similar problem. Found that resistor and thought it looked like a hack, but searching here, seems like it should be installed. I've been picking off problems one at a time. Was fighting multiple problems, but now everything seems to be right but idles 900ish cold and as soon as the thermostat opens, it jumps to 1200ish.
            2004 525i Manual - 1985 325E Coupe Manual
            • khiobrien2
              • Feb 2023
              • 102
              Apologies for reviving this comment you made a decade ago, but do you happen to remember how you solved this? I have the exact same issue and every post I see describing it is a dead end. This all started after I cleaned my ICV and throttle body.
              • tomstin
                • Mar 2015
                • 570
                Wow, let me think of all the stuff I've worked through over 10 years...and yes, I still daily drive it. I'm retired now so it's not getting a bunch of miles. As for the resistor, I've had it in and out a few times, I believe it's in now. My guess is your ICV is the problem as it started after the cleaning. But a few thoughts:
                Adjust the throttle body plate correctly. Evidently, that's critical. You need to look it up in the Bentley, I think it's a few thousands.
                Check all the temperature sensors back to the DME. At this point I think I've replaced every connector related to fuel and temperature along with all the sensors.
                My latest adventure was a pulsing idle. Ended up being the two wire spade connector on the thermostat housing. Open cold, closed at 113f. It's NLA so I wired in a switch on the dash.
                These engines are very finicky when it comes to excess air along with those temperature sensors. And as these engines continue to age, wiring is going to become more of a problem.
                Sorry for the lack of an easy answer...good luck!
