FPR leaking fuel.. A little help?
  • unitt01
    • Oct 2014
    • 513
    Hey guys my fpr is now leaking fuel and it's from the O ring that connects it to the fuel rail. Is the o ring replaceable or do I have to get a new fpr ? Thanks..
    FS: Plug n Play Second Trunk Light !
    My Parts for Sale Thread~
    x 1984 325e 2.7i ~ CastroMotorsport Built x Daily Driven
  • reelizmpro
    • 9533
    replace the o ring.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • goldenbb
      • Jun 2013
      • 208
      Fix it--fuel leaking onto a hot engine is a big no no unless you're trying to burn the car up.
      '90 zinno 325iS
      • TSI
        • Mar 2012
        • 691
        Yup, o ring is replaceable, i believe it may even be the same part as the injectors' o ring
        • betsy325e
          • Jun 2015
          • 81
          http://www.realoem.com/bmw/enUS/show...diagId=13_0233
          Injector o-rings and FRP o-ring are the same according to OEM diagrams.
          If it leaks with new o-ring, try to seat the o-ring properly before tightening the two 10mm bolts on either side, as sometimes just tightening the bolts won't create a good seal.
          Also make sure the threads on the fuel rail aren't stripped (seen this happen, particularly on the right-hand side next to the intake manifold where it can be difficult to get at that bolt).
          You can always get a longer 10 mm bolt and put another nut on the bottom if you've got some bad threads.
          • TurboJake
            • 3780
            and don't forget to lube it!
            Leave Me Transaction Feedback
            • unitt01
              • Oct 2014
              • 513
              Thanks guys! Just put in a new o ring and still leaking... So it's either now the fuel rail or the fpr?
              • unitt01
                • Oct 2014
                • 513
                Gonna try to get longer bolts and see if it just needs better tightening.
                • unitt01
                  • Oct 2014
                  • 513
                  Ok figured it out. PO had left the old o ring from an old fpr inside the fuel rail :x
                  Thanks again you guys :bow:
