Recommendations for flushing engine before new oil goes in?
  • E92E30Nut
    • May 2014
    • 135
    I would like to do what I can to flush out any gunk from the motor before I out fresh fluid in. Anyone have recommendations or specific products that work well to achieve this?
    Thanks in advance
  • george graves
    • 20003
    A mechanic friend of mine swears by this: http://www.cyclo.com/C19.html
    I believe it's sold under a few brands, but they are all are in an old school can with a pull tab.
    You'll know how well they work by how many warnings it comes with. The stuff that says "Only run for 5 mins" - you know might actually work.
    Pull the oil cap on your head, and look inside. If you see black, you might need it(and have issues). If your see more-or-less gold/orange color, I would skip it.
    Originally posted by Matt-B
      The safe way is to change the oil & filter, drive the car about 500 miles and change the oil & filter again. You can repeat that cycle a time or two if you want to. Looking into the oil fill cap will give a good indication of how dirty the engine is, as george graves said.
      The nicest thing you can do for your engine is to take it out once a week for a 20-30 minute highway speed drive. It takes that long for all parts of the engine to reach the temperatures needed to boil off combustion blowby condensates. If you do a lot of urban driving (lots of short low speed trips) reduce the oil/filter change interval to something like 2500mi to get rid of the condensates and keep the engine clean.
      Conversely, if your driving includes daily 20-30 minute highway speed driving, you can go the full interval (as indicated by the SI lights) on oil/filter changes.
      When it comes to oil and filters, you wan an oil with a high ZDDP content to protect the rockers. Amzoil has a good product and Rotella T is pretty good. There are racing oils with higher ZDDP content, but they don't have the detergent packages as they are meant to be changed frequently. The best oil filter is a Mobil-1 filter, but the OE or Mann filter is okay.
      • TobyB
        • 5288
        Removes power-robbing deposits
        Dissolves gum, sludge & varnish
        Helps free sticking valve lifters & rings
        In all my years as an idiot DIYer, I've never met a 'power robbing deposit'
        that didn't live in a fuel injector. Everywhere else, they just hang around and
        don't bug anyone.... well, except in the throttle body, but those are easy to clean.
        We have solid 'lifters', and a stuck ring on a BMW engine is usually a broken ring.
        I am firmly with Jim on this one- just reduce your oil change interval if you're worried.
        You run the risk of doing real damage with additives/flushes/bananas/snake oil
        in your oil, and the benefits are unmeasurable. Yes, it's NICE if the top of the
        head looks all spanky, but it doesn't matter much.
        t
        • george graves
          • 20003
          Deposits on the back of the valves are a real issue.
          • digger
            • Nov 2005
            • 6194
            Yeah don't flush it with anything
            • TobyB
              • 5288
              Oh, right- Ventil your Sauber, eh? But that's nothing an oil 'flush' would fix.
              I've never come across that very much- but then, I Chevron, too...
              t
