Water Pump Pulley Question
  • ButtJuice
    • Dec 2009
    • 2609
    Hey R3v,
    Need someone to hold my hand through this issue. So, I just put the harmonic balancer back on the crank (m20b25), however the pulley that goes on the water pump will absolutely not fit back on due to the HB being in the way.
    Any insight? Totally stumped. Lmk if you'd like a pic of what I'm talking about.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
  • ButtJuice
    • Dec 2009
    • 2609
    Update:
    This motor I've been putting together is a Super ETA bottom end with an i cylinder head. I just put my old i harmonic balancer on and, oh my goodness, it all fits. However I'm concerned, why wouldn't the other one work? Will I F things up by putting an i HB on an e block?
    1991 318is - Sold
    1986 325 - Sold
    • ButtJuice
      • Dec 2009
      • 2609
      So mind f'ed right now. The water pump for each motor wouldn't be any different.. So why would one harmonic balancer not be compatible?
      1991 318is - Sold
      1986 325 - Sold
        You do know that the belt that drives the water pump also drives the alternator, right?
        There are three pulleys on the harmonic balancer. One for the alternator & pump, one for the power steering, and one for the A/C. Unless you have some odd ball harmonic balancer there should not be any problem with the pulley/belts.
        • TobyB
          • 5287
          I want a pic- cage match of the 2 harmonic balancers side- by- side.
          BMW did some odd stuff- it would not be too shocking if they had a different
          balancer and waterpump pulley for the seta...
          t
          • ButtJuice
            • Dec 2009
            • 2609
            yep, I'm aware of that.
            t
            Yeah idk it's really odd, the balancers compared side by side are a bit different in their geometry. The "i" was the only one that would work. I'll bring some pics later.
            1991 318is - Sold
            1986 325 - Sold
              • 34844
              there are early and late pulleys - they are different diameters.
