Well I just pick up an 1988 325ic Manual transmission w/ 165k Bone Stock rolling on stock wheels (bottle caps). The car is in good running condition except for the rear end noise I'm experiencing while driving above 30 mph. Sound does not change when in neutral and coasting down the highway. Had a mechanic took a look at it and told me it could be the pinion bearing within the diff. I tried changing the fluid and recently replaced the rear brakes (pads, rotors) and whining noise is still presence. Worst case, if I were to replace the diff I was thinking about getting lsd, (noob question) what is the best gear ratio for daily driving as I too take the highway to work. Does it affect the speedometer? I know for sure the rpm will have a slight change depending on diff ratio. If it does affect the speedometer, will I have to change something like the speed sensor?
Did a little research...3.73 seems to be best all around. What do you guys think?
