Eta 2.7 block with is 885 head question
  • Andy.B
    • Sep 2011
    • 1650
    #31
    It sounds like I need to swap out my i manifold for an eta manifold on my 2.7i.
    I'm running a 230k eta bottom end, bimmerheads 274 cam, motronic 1.3, and full i exhaust. It already drives fantastic. If I can make even more power by simply swapping in an eta manifold, then I am absolutely going to do it.
    • mikebloco
      • Feb 2015
      • 190
      #32
      So the eta intake on a franken 2.7i motor flows more than the i intake!?!?!? Even after 4,000 rpms???? I would ASSume it would just flow better down low
      • modernist
        • Apr 2014
        • 283
        #33
        Originally posted by ForcedFirebird
        It's a very strong combination. You get more TQ than an eta, but the better breathing of the head and cam, so more HP to boot. It does choke a bit at the top end, drops off pretty rapidly at 6000 or so.
        Do you still have the graph lying around? Here's a quickie graph of mine I made today (no idea how accurate the numbers are, it's an app that uses the accelerometer on my phone along with weight, gearing, aerodynamics, weather ...) but it illustrates the torque characteristics nicely. How is it different with the eta manifold?
        1986 327i
        transaction feedback
        DIY thing
        meh
        • mikebloco
          • Feb 2015
          • 190
          #34
          The tq is definitely much nicer than just a b25
          • mikebloco
            • Feb 2015
            • 190
            #35
            Bump. I need to know more about this
            • digger
              • Nov 2005
              • 6163
              #36
              I'd be tempted to work on an eta head given the engine likes the small runner Intake manifold, on a engine that is sub 200bhp that is
              • jayuuey
                • 414
                #37
                subscribed.. waiting for confirmation on this.
                • djjerme
                  • 5082
                  #38
                  I am kinda curious about this as well.
                  I have 88 Super Eta I picked up from auction this month, and we were thinking of swapping one of my extra i intakes/TB/AFM/ECU/injectors on it.. Would like to see flow numbers or some sort of solid evidence.
                  2016 Ford Flex
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #39
                    If you click my link above, we posted flow numbers for the eta, seta and i top ends.
                    No, the eta manifold does not flow better, but coupled with the 2.7i (flat pistons/885 head, eta manifold ported to accept the "i" throttle body), it gives more torque and power than a "i" manifold - but also, power drops more rapidly after 6000rpm than the "i" manifold on a 2.7i.
                    john@m20guru.com
                    Links:
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #40
                      I have the WinPEP files from the dyno on my SD card - in which I left at the dyno during the last tuning session - won't get it back until I go back to tune another car, or am on that side of town.
                      john@m20guru.com
                      Links:
                      • modernist
                        • Apr 2014
                        • 283
                        #41
                        Looking forward to it
                        1986 327i
                        DIY thing
                        meh
                        • 4x4_e30
                          • Sep 2013
                          • 164
                          #42
                          Extrude honing might be worth a shot.
                          • mikebloco
                            • Feb 2015
                            • 190
                            #43
                            I'm in the middle of a 2.7i build right now and I never really take my car past 6k rpms any ways. I have a eta intake and an i intake so I might give this a shot.
                            • jayuuey
                              • 414
                              #44
                              Is the power drop described negligible when comparing the E to I intake manifold? With my current setup, e bottom full i top, there isn't much power after 6k anyways. The tq difference in your dyno results makes me want to swap manifolds right now!
                              • JeLani
                                • Aug 2015
                                • 1552
                                #45
                                Can someone , or the op , tell me how the cluster swap works for 2.7i's?
                                1986 LTW M52 (First project 2015- )
                                1998 e36 328ic/5 -
                                Roundie alpina pig cheek’d (1969)
                                1967 2002 parts car
                                1994 318iS junked.
