Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1472
    #346
    Das Beast Body And Paint
    80 lbs of steel riding home in the trunk of my rental car. It noticeably improved the traction. :devil:
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • cuccinater
      • Oct 2016
      • 1
      #347
      following
      awesome build, cant wait to see it finished.
      • dvallis
        • Oct 2015
        • 1472
        #348
        Das Beast Body Shop
        And here's the steel in Das Beast. Perfect fit! :devil:
        Decided to rock some bronze STR 518's. After WAY too much research I figured you can't beat them. $99 each from a local store. 17x9 4x100/114.3 73.1 ET22.
        They actually look more like the 1st picture in person. I think the camera flash "over blings" them, if you know what I mean.
        Just an FYI, here is a small portion of my wheel research. I wish v-bulletin supported html tables, since this looks like crap.
        Name Size Weight Offset Bore Price Comment
        Drifz 308B Spec R 17 x 9 31 15 73 ? $135
        AODHAN AH03 machined silver 17 x 9 24 25 73.1 $104
        TD Pro Race 1.2 17 x 9 21 ANY 57.1 $260
        STR 505 17 x 9 21 22 73.1 $108
        ESM004 gunmetal 17 x 9 22 25 57.1 $124
        ESM 007 17 x 9 18 20 67.1 $230
        MST MT07 17 x 9 21 20 73.1 $122
        JNC001 matte black 17 x 9 25 20 73.1 $126
        JNC001 machined silver 17 x 9 25 25 73.1 $138
        STR 514 silver 17 x 9 21 20 73.1 $153
        Tracklite Clutch 17 x 9 20 25 73.1 $160
        XXR 531 black platinum 17 x 9 21 25 73.1 $175
        Rota GRID hyper black 17 x 9 20 20 57.1 $180 True 4 lug
        Varrstoen ES2 17 x 9 23 25 73.1 $200 True 4 lug
        Klutch ML7 17 x 9 23 15 73.1 $220 True 4 lug
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1472
          #349
          Das Beast Body Shop
          Got the new wheels back to the garage with tires. They look great. Bronze is very subtle.
          Here's the difference in tread width, 205/55/15 to 245/40/17. New tires look massive compared to the old ones.
          China is getting brave with their marketing. I'm pretty sure these are not "forged monoblock" for $99. Or I got a KILLER deal. :devil:
          Last I heard STR has not bought Rays Engineering either. But who knows?
          Awesome new RUBBER for the road.
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1472
            #350
            Das Beast Body Shop
            Tie to revisit the sunroof. It needs a permanent patch. First thing is removing the old sunroof AKA boat anchor. It weighs 15 lbs! (50 lbs of sunroof mechanism previously removed)
            Now scrape off all the goop I used to temporarily seal it.
            Will use 20 gauge steel bonded with 3M 8115 and riveted to patch this hole.
            Geared up for body work.
            Preparing the metal for proper bonding.
            Sunroof patch template fitted. 24x37 20 gauge
            Rear bulkhead template in progress. Back deck will class it up a bit. Only requires one break bend.
            Bottom piece fitted. Plasma cutting & one break bend required. It's not for looks. Racing regulations require a continuous steel bulkhead between the driver and fuel cell.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1472
              #351
              Das Beast Body Shop
              Time to tackle more custom interior work. First step: assemble the new wheel, hub and quick release.
              View from the driver's seat. Wheel is too high for my liking. Need to lower it.
              First drill out the shear bolts. They are a pain in the a$$.
              Now pound a star head socket into the hole and break the thread loose.
              Here's the damn thing removed. Repeat for the other side,
              Temporary ghetto lowering spacer. Will fabricate a real bracket later.
              New view from the driver's seat. Much better.
              View of where the center console will go.
              Now, our plan for this build is create a custom metal dash without welding. Plasma cutter, break bends and sheet metal screws only. Dash will be made in removable modular panels. Here's it is starting to take shape.
              New view from the driver's seat. My gauge layout is definitely going to change.
              Making the dash end caps. Cuts and bends only.
              Fits great.
              Center console is shaping up. Getting too darn hot in the garage so I called it a day.
              2002 E39 M5
              • peterman
                • Feb 2015
                • 165
                #352
                Will you be running a defroster?
                That looks like a lot of metal for the dashboard. I would think you can remove a lot of that on the passenger side. But I guess if there's no welding you can use aluminum sheet anyway.
                Looking great!
                • dvallis
                  • Oct 2015
                  • 1472
                  #353
                  Defroster?! Ha! I live in Texas! If ice forms here the world is ending. :devil:
                  Don't worry. That's just the dash template. Will be lots of metal carved out of it before we are done. I expect it to look something like this.
                  2002 E39 M5
                  • peterman
                    • Feb 2015
                    • 165
                    #354
                    Perhaps defogger is a better term.
                    There are plenty of humid days where the windshield will fog up in cool weather. I have heard putting Dawn on the windshield helps in the absence of a defogger.
                    I've seen guys drive around the paddock with a squeegee (and even a towel duct taped to a stick!) to wipe the inside of the windshield because they can't reach it when they are harnessed in.
                    Then they wedge it behind the seat when they go race. Not the best idea but I've seen it done.
                    • dvallis
                      • Oct 2015
                      • 1472
                      #355
                      Very classy, towel and broom stick. :-)
                      I know what you mean about the fogging. Has happened to me racing coupes in the rain. Honestly I haven't worried about it for ages since I was driving open wheel cars. Defogging = Glove across visor
                      Looks like we'll be inventing a system of defogging blowers for Das Beast. This ought to do the trick. $150 heater + blower from Summit. One in the dash, one in the trunk.
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1472
                        #356
                        Sheet metal dash was a good idea, but I lucked into this fiberglass dash a R3v member had gathering dust. Apparently not their lightest work, but it's sill freaking fiberglass. :devil: Thanks Chris and VSR.
                        In your best Gollum voice .... "My Precious"!
                        2002 E39 M5
                        • Digitalwave
                          is a poseur
                          • 6281
                          #357
                          Engine oil temp sensor screws into the block (below oil filter) where oil pressure idiot light sensor used to go.
                          Someone mentioned this already, but did you check clearance/penetration of the brass adapter potentially blocking the oil passage? I ask because I am about to mount my oil temp sensor in the same spot.
                          Spent way too much time reading this thread at work today. Keep up the great work!
                          RISING EDGE
                          • mila325
                            • Sep 2015
                            • 82
                            #358
                            Rest in piece photos. Pls get them back d;
                            • dvallis
                              • Oct 2015
                              • 1472
                              #359
                              Photo bucket is down. Again. Should be back. Otherwise I'll find a new site to host these photos.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1472
                                #360
                                Tonight may need to be Das Beast thread mega image repost. Ugh.
                                2002 E39 M5
