Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1472
    #406
    New fans are here. Exactly 23" x 12". Will fit perfectly in the front frame box.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1472
      #407
      Spent the afternoon fabricating brackets for the fans. Most of the time was planning and getting materials.
      Here's the end result. Looking good. Very solid. The fans don't move at all. Everything is held on with lath screws until we weld it all in place.
      I need to swap out the rear cross bar for mild steel. I grabbed a bar of aluminum stock by mistake.
      New intercooler mounting location allows more airflow to the radiator. Will need to cut a big ass air intake in the bumper though.
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1472
        #408
        Continuing the front end work. Test fitting the intercooler.
        Making the mounting brackets from 14 gauge perforated steel flat stock.
        Getting there. You can see where I'm going with this.
        Final touch for stability. You wouldn't believe how ridiculously solid this is. I can literally stand on it. Will support the intercooler no problem.
        That's more like it. This is sexy.
        Will be doing the intercooler top bracket and bumper air intake mod next.
        2002 E39 M5
        • 2mAn
          Señior Mod
          • 20619
          #409
          You should look at Charlie's (Sh3pak!ing) thread. He drilled some nice holes in his bumper to get the air through.
          It's coming along!
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • dvallis
            • Oct 2015
            • 1472
            #410
            Link to the thread? No members listed under Sh3pak!ing.
            2002 E39 M5
            • 2mAn
              Señior Mod
              • 20619
              #411
              It's because his name is ridiculous and I always misspell it
              Sh3rpak!ng
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              • dvallis
                • Oct 2015
                • 1472
                #412
                So, that link gave me a great idea. He drilled bumper vents with a hole saw, which is a very simple, efficient way to do it.
                I'm not fond of the round hole look, but it gave me an idea. If I start with the round holes then connect each pair, the result is OEM-ish looking rectangular vents. Exactly what I wanted. :devil:
                That's a great $0 solution. I might even add some black mesh to finish it off.
                2002 E39 M5
                • 2mAn
                  Señior Mod
                  • 20619
                  #413
                  I wouldnt do the middle vent that way because the trim is split, maybe just two big ones?
                  I would try to replicate the lower vents in the IS cowcatcher lip
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • dvallis
                    • Oct 2015
                    • 1472
                    #414
                    Get my grille on
                    So, look what arrived today. 16"x48" perforated hex grill mesh sheet in black. 77% open area for excellent airflow to the intercooler and radiator.
                    I was going to use this just for inlets, but it's so nice I may also fab a custom grille with it
                    It's more open than it looks from a distance. Also has nice 3D profile.
                    2002 E39 M5
                    • downforce22
                      • Aug 2009
                      • 3192
                      #415
                      looking good, glad you flipped the intercooler. curious to see how your mesh ends up looking
                      • dvallis
                        • Oct 2015
                        • 1472
                        #416
                        Alright, time to finish off the front end hardware.
                        First thing is the radiator bottom bracket. We want it to be quick release for fast change if damaged. Two part bracket gets it done.
                        New bracket goes here, but old radiator mounts are too high.
                        Angle grinder made quick work of them.
                        Bracket tacked in place with lath screws. So far so good.
                        Radiator in place with top brackets holding it as well. Fits great. Very solid.
                        Intercooler mounted with top bracket in place. Between that and the large bottom bracket it's definitely not going anywhere.
                        Here's the final product. It's a nice piece of work. Looks OEM. Will have good airflow.
                        Best thing is it fades right into the stock bodywork. Won't even be able to tell it's there with the grille and headlights on.
                        2002 E39 M5
                        • doorman
                          • Mar 2015
                          • 360
                          #417
                          Great progress!!
                          • dvallis
                            • Oct 2015
                            • 1472
                            #418
                            Learning To Weld
                            Keep in mind while reading this post that my father is a Master Welder. He's done it all ... TIG, MIG, Arc, welding overhead, standing inside marine diesel engines and hanging in the air building hydroelectric dams. His welding bead looks like a machine did it. Soooo ... there will be some humor when you see my first attempts at MIG welding.
                            Started practicing on 12 gauge scrap steel and 18 gauge left overs from the car. First try was damn ugly. Lots of burn through. And the wire welded itself to the tip. Which I had to file and re-bore. Ugh.
                            After a call to Dad: Lower voltage, lower wire feed speed, tip further from the metal, don't stay in one place. Still a disaster.
                            But, I'm nothing if not determined. Bolted on some more scrap and kept practicing. Worked from left to right. By the last bracket its starting to look not so much a disaster.
                            Kept at it until I was able to do this. Not bad. At least good enough to weld the radiator and intercooler brackets. I'm ok at making spot welds. Still terrible at laying a bead along the edge of the bracket. Will stick to what works.
                            Thanks for the tips Dad. Hope you get a laugh from the pictures. :devil:
                            2002 E39 M5
                            • badwella
                              • 357
                              #419
                              Awesome thread, man. Just sat down from page 1 and read it all. Definitely going to check in on this regularly.
                              Check out Weldingtipsandtricks.com and his Youtube channel as well. Loads to learn from there if you haven't already been watching. Mostly TIG, but good MIG lessons too.
                              Also, trying to weld through paint is going to make your welds look like dogsh*t regardless of your welder settings (unless you are using special weld-thru primer). Runs a high risk of porosity too. Use a flap disc and get down to clean bare metal and your beads will lay down much better.
                              P.O.S 1989 325is - aka Project Sh*tbox
                              Project Shitbox - Restomod and other stuff - soon to be 328is
                              • dvallis
                                • Oct 2015
                                • 1472
                                #420
                                Das Beast Fabrication Shop
                                "Luke, I am your fathah"
                                Electrochromic helmet makes welding 1000X easier. Now I can SEE the frigging bead!
                                Much better. I also had an "Ah Ha" moment while welding. After that it became a lot easier. Shows in the results.
                                Mostly finished and welded bracket system. Notice I moved the outside 45 degree bends lower to make room for intercooler plumbing.
                                Test fitting the intercooler plumbing.
                                My new favorite tool. Plasma cutter.
                                It did a great job making a hole for the intercooler plumbing.
                                Valence bolted in place with new brackets and ready for paint. Will finish the bumper tomorrow.
                                2002 E39 M5
