Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1336
    Yeah, I was wondering the same. ARP says 3 equal steps ending in 70ft/lbs. https://cdn2.arp-bolts.com/instructions/201-4305.pdf
    Thanks for the reminder. We'll definitely retorque to 70.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • Old525i
      • Oct 2015
      • 32
      #1337
      After retorquing, check the valve lash gap.
      • dvallis
        • Oct 2015
        • 1474
        #1338
        Engine all done. Head studs re-torqued to 70 ft-lbs, plug wires sorted, fuel pressure set to 50 psi, oil, fuel and water topped up.
        She runs! We dialed in a few turns on the throttle body butterfly set screw and it idles beautifully at 1000 RPM. No white smoke on throttle lift, so the ring issue is solved.
        Bled the cooling system and idle temperature settled down to 180F. We took it for a few victory laps of the block. No oil, fuel or water leaks. Throttle response is good. She's got a "good enough" fuel map for now, so we didn't get into it. It's tuned a bit rich just to be safe.
        We noticed some "blue fuzz" around the cam gear from the blue kevlar timing belt, so that's got to be addressed. I never liked that damn aftermarket belt. It was bar tight going on, hard up against the tensioner. We're switching back to a stock belt. Not screwing with timing on an interference engine like this.
        Victory!
        2002 E39 M5
        • Metallated
          • Dec 2016
          • 1074
          #1339
          Congrats! Car is looking amazing
          • zaq123
            • Jul 2016
            • 1515
            #1340
            Victory!
            There is no problem with that blue belt. I'm be more concern about tensioner pulley etc that causes the belt to rub on the cover (most likely the issue)
            • digger
              • Nov 2005
              • 6145
              #1341
              yeah i've been using a fuzzless blue belt last few thousand miles. you haven't use a povo spec tensioner have you ?
              • dvallis
                • Oct 2015
                • 1474
                #1342
                No, just a stock tensioner. But the damn belt is so tight that the tensioner spring won't even fit in there. Belt is basically bar tight against the gears and tensioner without spring. Can't be good. Maybe we got a bad belt ... don't know. I ordered a stock belt and will measure it against the Kevlar one.
                2002 E39 M5
                • digger
                  • Nov 2005
                  • 6145
                  #1343
                  yeah that doesnt sound right. it should slip on like stock. you arent running a real thick gasket are you?
                  normally the spring is preinstalled and the tensior locked off in the full retracted position and then released when the belt is on.
                  • zaq123
                    • Jul 2016
                    • 1515
                    #1344
                    Kevlar timing belt went on in five seconds flat. Timing marks lined up correctly this time. :devil: Crank turned with one finger on the breaker bar. Nice!
                    post 1339 has you struggling with the belt.
                    old post 308 (attached) got you a 5 sec install. I'd imaging it was the exactly same belt, no?
                    Photobucket pics are all fuzzy......... Maybe installation error this time? got post 308 pic in a better quality?
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1345
                      It's so tight we can barely get the belt over the tensioner in fully locked back position. No way for the tensioner to ever move. So yeah, definitely feels wrong.
                      We're running a 0.120" MLS head gasket vs the 0.070" stock. I guess the extra 0.050" might make the belt tighter, but that's only 1.27 mm. Pretty damn small difference. Same head gasket as in the photo below.
                      #_I_HATE_PHOTOBUCKET
                      Here's that pic
                      2002 E39 M5
                      • zaq123
                        • Jul 2016
                        • 1515
                        #1346
                        as a side note, I don't know if blue belt is much stronger vs oem spec..I tested them both , Continental and blue one....both of them have the same stretch when the engine is turning.... stretch nets about 2 degrees of retarded cam timing.
                        I went with the blue belt as it looks like of much better quality vs Chinese made continental. Although I'm sure Conti belt is up to par as well
                        • zaq123
                          • Jul 2016
                          • 1515
                          #1347
                          It's so tight we can barely get the belt over the tensioner in fully locked back position. Not way for the tensioner to ever move. So yeah, definitely feels wrong.
                          Was it the same belt? Picture shows that the tensioner adjustment was +/- in the middle of its range. If the same exact belt and other components...possible installation error?
                          • digger
                            • Nov 2005
                            • 6145
                            #1348
                            its not one of dodgey nuke gears with teeth that are wrong is it?
                            you are also better of keeping the rotor adapter as it works to spread load of the fastener to the alloy cam gear
                            • zaq123
                              • Jul 2016
                              • 1515
                              #1349
                              whaaat? need more info...how one can check that the gear is the good one?
                              • digger
                                • Nov 2005
                                • 6145
                                #1350
                                belt doesnt fit into the teeth very nice
