Thermostat going out?
  • lovemyiX
    • 8
    What should be the temperature in my coolant reservoir, the same as the thermostat rating? I'm getting a reading of 150 deg. with my "thermopen" cooking sensor. The gauge used to be right at 12 o'clock but now it is at 11. I'm thinking it's the 'stat. Thanks
  • dasmanschaft012
    • Apr 2014
    • 642
    maybe, it's a cheap part just replace it
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
    • jeffnhiscars
      • Jun 2011
      • 6010
      The reservoir temp is going to be less than internal coolant temps so don't go by that. Best to measure with an IR gun on the tstat housing and to also check the radiator for cool spots which means it needs attention
      Use an 80c stat and your gauge should read below mid point except during extended idling
      Alice the Time Capsule
      • ttrousdell
        • Nov 2009
        • 1770
        I wouldnt worry about it.
        The Build:
        • packratbimmer
          • Dec 2009
          • 1331
          Confirm that the system is holding pressure. It will not operate the same if there are air leaks.
          • lovemyiX
            • 8
            Thanks everyone, all good advice. I am going to change the thermostat.
