2.7 build, can someone dumb it down for me?
  • Reynoldsyo
    • Sep 2014
    • 5
    Alright hey guys, i can see there is a lot of info on this. Im contemplating doing the swap with a 1987 525e motor and the head off my 1985 323i. From a quick read i saw that they should bolt together without any modification, but id like to know, will i need the harness from the old car? should i port the head? (i plan to go turbo) I will obviously need an MLS headgasket and upgraded head studs, but apart from that will i need to do anything? change valves? i plant to do alot of this myself, so id like to know what im in for.
    Thanks!:p:)
  • digger
    • Nov 2005
    • 6119
    use a bone stock 885 head if going turbo. id convert to the b25 electrics and then get a PNP MS
    • mikebloco
      • Feb 2015
      • 190
      Whats your budget?
      • JeLani
        • Aug 2015
        • 1552
        i bought mine already swapped. not fully built but only swapped. i harness , 885 of course make sure the head is in good shape , 325i ecu, 7k guage and coding plug (depending on the year of your car) im using an early IS coding plug because i have an 86. this beats having a stock eta but not by far because the compression is still low.
        1986 LTW M52 (First project 2015- )
        1998 e36 328ic/5 -
        Roundie alpina pig cheek’d (1969)
        1967 2002 parts car
        1994 318iS junked.
        • Reynoldsyo
          • Sep 2014
          • 5
          Originally posted by mikebloco
          Whats your budget?
          budget for the 2.7 is about 2k, not going to worry about turbo straight way, ill bolt that on later, i just want to build the motor so when i do bolt it on it can handle it.
          • Reynoldsyo
            • Sep 2014
            • 5
            So series 2 325 engine harness?
            Whats PNP MS?
            • Reynoldsyo
              • Sep 2014
              • 5
              Is it completely out of the question to do it with the 731 head? Will i have to go an 885 head?
              • jeffnhiscars
                • Jun 2011
                • 6010
                I'm putting a 731 head on an ETA but I have no intention of doing a turbo. Bigger valves, ported, motronic upgrade, dual valve springs, cam etc etc...I'm about at $2k in parts and machine shop.
                If turbo is On the agenda listen to digger
                Alice the Time Capsule
                  • 37829
                  In my opinion the 731 head needs quite a bit of work to compare to the 885. If the 731 was ported and running the bigger valves from the 885, sure it's good. All depends how crazy you want to go.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • modernist
                    • Apr 2014
                    • 283
                    1986 327i
                    transaction feedback
                    DIY thing
                    meh
                    • e30onBBSs
                      • Dec 2014
                      • 1347
                      BMW tech
                      Umass Amherst
                      05 wrx sti
