87 325is valve adjustment
  • Marqueln23
    • Nov 2015
    • 12
    I'm doing a valve adjustment and I know the firing order but what does it exactly mean? What are the exact steps?
  • ELVA164
    • 4861
    The simplest way to do it if you're worried about missing something is to work your way backward from the front of the engine one valve at a time. Just wait until the cam lobe is pointing away from the lifter (up) before adjusting. If you want to speed the process up, make a little chart of the valves and do them as the cam lobes start to point up. Just mark the valves you've adjusted on the chart as you go.
    • bryant.cw
      • 209
      Download the service manual and follow the steps, it's very easy. I work very slowly and this job takes me about an hour from jacking it up to firing up the motor when I'm done.
      If you have a manual transmission, you can do what I do. I don't feel like messing with the crank bolt so I put the transmission in 5th gear and jack up one rear wheel. I then turn the wheel by hand, or with an extension on one of the lug nuts, to turn the motor over. Make sure to disconnect the battery first. I have a limited slip differential and it still works, just make sure it's jacked securely as the opposite wheel will be trying to rotate, eg: it will be trying to push the car off the jack.
      I put a little dot of silver sharpie paint on each rocker, or use a grease pencil or whatever, to mark them as I go along.
      • jeffnhiscars
        • Jun 2011
        • 6011
        I use a sharpie and mark them as I adjust them
        Alice the Time Capsule
        • ELVA164
          • 4861
          Why disconnect the battery?
