chipped and 19 lb injectors, won't start.
  • RackedE30
    • Dec 2014
    • 12
    I recently removed my intake manifold to have it painted and while it was off I installed a 91 octane 19b fuel injector chip from sssquid. I also installed brand new 19 lb fuel injectors. I reassembled everything, all new gaskets, and made sure absolutely all electrical connections were plugged back in. The car refuses to start. Sometimes if i let it sit overnight it will fire up but then dies right away. It sounds like its very close to starting when cranking but just can't get over the hump. any advice would be awesome, thanks in advance.
  • E30SPDFRK
    • 5714
    Make sure you reinstalled the fuel hoses on the hard lines correctly, it's very common to hook them up backwards.
    Byron
    Leichtbau
    • RackedE30
      • Dec 2014
      • 12
      yup checked those, and I'm pretty certain i don't have any intake leaks
      • Hooffenstein HD
        • Nov 2012
        • 1388
        Checked the wires on both sides of the C191 plug?
        • RackedE30
          • Dec 2014
          • 12
          yup, both sides are good
          • RobDog
            • Aug 2012
            • 188
            CPS and CID connectors swapped/mix?
            • digger
              • Nov 2005
              • 6183
              Do the Plugs Get wet? Do all the plugs fire ?
              Fuel pressure?
