Changed the thermostat now the oil pressure light stays on!
  • lovemyiX
    • 8
    Does the wiring for the pressure switch run anywhere near the thermostat? The thermostat came out so fast and easy!
  • Bimmerboy91
    • Feb 2007
    • 622
    May be a coincidence. Check the switch see if anything came undone.
    • lovemyiX
      • 8
      I think the wire comes up from the switch under the oil filter mount passes right in front of the timing cover, under the thermostat and disappears into a harness. Any body know the color of the wire? The Bentley wiring diagram does not show the pressure switch just the level sensor, page 15-51, as far as I can see.
      • jeffnhiscars
        • Jun 2011
        • 6011
        are you sur its th oil pressure light and not the oil level sensor light.
        Alice the Time Capsule
        • lovemyiX
          • 8
          Yes, I'm talking about the light next to the battery light below the speedo, one of the warning lights, it has the oil can with the drip at the spout.
          • vpilarrt
            • Jun 2006
            • 2096
            Oil pressure switch wire color is brown/green
            • lovemyiX
              • 8
              Thanks for that info. I have determined that the sensor went out following the Bentley troubleshooting. The wiring does pass under the thermostat and I had a very tight zip tie on it to keep it from hitting the fan belt so it threw me off thinking it was the wiring.
