Head gasket install problem
  • Sasquatch440
    • Jan 2016
    • 36
    hey guys, long time lurker, but first time posting.
    im putting a new headgasket on my e30, and i had an out of shape dowel pin ( which i am now replacing) and i put the head gasket down on the block and the edge of the pin pulled up ever so slightly on the headgasket. was wondering if itll be ok, or should i go ahead and buy another gasket? which will be the 3rd because the first fell off my toolbox and bent a corner... this car will eventually see boost
    heres a picture
  • dnguyen1963
    • Nov 2011
    • 2651
    Use a Dremel and round off the part that pops up.
    • Sasquatch440
      • Jan 2016
      • 36
      of the gasket? that doesnt sound like a good idea..
      • SkiFree
        • Jun 2011
        • 2766
        Might not "sound like a good idea" but it will work if you have a steady hand.
        I really don't think you will have an issue in the first place.
        ADAMS Autosport
        • dnguyen1963
          • Nov 2011
          • 2651
          That's nothing. I have done worse with the Dremel.
          • AndrewBird
            The Mad Scientist
            • 11898
            I would agree with this. There is plenty of extra material around the damage, and it is around a bolt hole, not a fluid passage, so you should be fine.
            • digger
              • Nov 2005
              • 6207
              it'll flatten out under the the 50t+ load, its glorified cardboard
              • TobyB
                • 5297
                I'm with Digger- squash it with head bolt torque. Or trim it back just a tiny bit with a
                sharp matknife blade. The only possible issue could be if it folds back on itself (which it won't)
                and makes a double- thickness high spot.
                t
                • pandaboo911
                  • 2070
                  That part doesn't do anything, it's not near any sealing surfaces so just run it.
