Unstable Idle, Only When Warm
  • jbruch694
    • May 2012
    • 44
    UPDATE: Been a long time, but I am still having this problem.
    I installed a new O2 sensor, OEM Bosch unit, and still get code 1222. The engine starts fine, idles fine when cold, but sometimes wavers between 600 and 900 rpm, only when warm. Typically only does this when I do a hot restart. Another note, sometimes this thing has a very hard time restarting when hot and I have to floor the gas and crank for 5+ seconds. Giving it gas off idle, it stutters a bit, and isn't too quick to respond, but never stalls.
    Still have the same symptom of CEL always on. If you pull the ECM harness to reset it, then drive again, it comes back on initially only at idle, and goes away when you give it gas, but eventually comes back on at cruising speed and stays on. Only fault code is 1222.
    Have checked for vac leaks, found a tear in the intake boot, replaced it, same problems. Checked again for vac leaks by blowing smoke into the intake and found none.
    Tested resistance on coil, was a bit high, put a known good one in, same issues.
    Got a good ICV for free, swapped it, same issues.
    Got a good AFM for free, swapped it, same issues.
    Tested plug wire resistance and it was within spec.
    Spark plugs are NGK coppers and have about 1000 miles on them.
    When it got warmer out, I smelled gas and it turned out the gas cap leaked vapor. I replaced it, no more leak, and same issues.
    Swapped ECMs, no difference.
    Valves were adjusted 4k miles ago.
    I wire brushed all the grounds I could find.
    I'm honestly at a loss for what this could be, especially because the symptoms are that of a typical vacuum leak. Is there any non-obvious spot where there could be a vacuum leak, like the EVAP system or the brake booster? Should I pull the injectors and have them tested? I tested the resistance and they all checked out, but could they be leaking or firing intermittently?
    • jbruch694
      • May 2012
      • 44
      Forgot to add, I am in Boulder, CO where the altitude is about 5500 feet above sea level, and I know these cars don't have MAP sensors, could the altitude be messing with it? It ran fine when I was in MD and seemed to run worse after a few weeks out here.
      • packratbimmer
        • Dec 2009
        • 1335
        Did you look at the check valve for the charcoal container? It is under the throttle body.
        • Kershaw
          • 11822
          Fuck it dude, there's always this solution:
          Also, your method of testing for smoke leaks isnt that great. It needs to be pumped in to maintain 2-4 psi. And plug the exhaust. Using a oily rag (burning, obviously) in a can that's securely attached to the intake in some way with a capped exhaust would be better way to test than what you're currently doing.
          AWD > RWD
          • mrsleeve
            • Mar 2005
            • 16390
            temp sensor for the ECM not the idiot light, or how about a blown head gasket maybe???
            Originally posted by Fusion
            William Pitt-
