Bremi ignition wires won't fit on Bosch copper plugs?
  • jasonbk
    • Aug 2011
    • 555
    So I was changing out the spark plugs(Bosch w8lcr copper),ignition wires(Bremi) ,caps & rotor(Bosch).
    After putting everything together I tried to plug in ignition wires into spark plugs - but all six of them won't fit onto the spark plugs.
    It looks like the metal hole within the spark plug wire is too small for terminal nut on the spark plug.
    Do I have a faulty ignition wires or am I missing something?
  • estoguy
    • May 2013
    • 1087
    Did you take the terminal cap off the top of the spark plugs? This will expose the threads underneath. Then your plug wires should fit then.
    Estoguy
    • modernist
      • Apr 2014
      • 283
      The little nut on the end of the spark plug threads off. Do that and your wires will fit.
      1986 327i
      transaction feedback
      DIY thing
      meh
      • jasonbk
        • Aug 2011
        • 555
        Thanks guys. I was super confused by it.
        When I swapped in the m20, it came with some hotwire universal ignition wire - so I never had to screw out that nut on the spark plug.
        • TobyB
          • 5298
          Some plug caps no longer unscrew...
          t
          • estoguy
            • May 2013
            • 1087
            Well, since he's running an M20, he should be running the NGK ZGR5A plugs... they still do.
            Estoguy
            • modernist
              • Apr 2014
              • 283
              A set I bought once had caps that didn't come off, but I bought them from NAPA. That was the last time I bought from NAPA.
              1986 327i
              DIY thing
              meh
              • Kershaw
                • 11822
                That happened to me once too. I broke the plug trying to remove that cap...
                AWD > RWD
                • TobyB
                  • 5298
                  Bosch w8lcr copper
                  I had a memory that the Botch ones are starting to become non- removable.
                  But then, I distinctly remember paying the electric bill, and the power just got shut off....
                  t
                  • jasonbk
                    • Aug 2011
                    • 555
                    I finally got around get those nuts off of spark plugs. There was no problem with getting them out.
