2.7 or 2.8? whats the diff....
  • luvin my 325es
    • Jul 2006
    • 45
    Difference? Crank, pistons?
    I want to use a donor 87 325is to stroke my 86 235es.
    I read about using a crank from 524i? TD, eta block, rods.
    Top half , from pistons , head, intake, ecu would be from donor is.
    Would that be a 2.8 stroker?
  • rs4pro3
    • 5808
    that would be a 2.7, to get 2.8 you have to bore the block and install larger diameter pistons.
    85 325e 2.7 ITB'd stroker
    • SA E30
      • 1248
      U could either bore the block.
      Or use a longer stroke crank
      84mm piston and 81mm crank = 2693.3cc
      85mm piston and 81mm crank = 2757.8cc
      86mm piston and 81mm crank = 2823.1cc
      84mm piston and 84mm crank = 2793.1cc
      85mm piston and 84mm crank = 2860.0cc
      86mm piston and 84mm crank = 2927.7cc
      84mm piston and 86mm crank = 2859.9cc
      85mm piston and 86mm crank = 2928.1cc
      86mm piston and 86mm crank = 2997.4cc
      These r just a few examples... off the top of my head using BMW cranks (324td / eta , M52B28 , S50B30 ) and std piston, oversize, and my fav 86mm piston ;)
      Just to show u that u can get a 2.7lt or 2.8lt from a no of combinations.
      • Sean
        • 5793
        He could also use an S52 crank, 89.6mm - that would get you damn close to 3.2i with the 86mm pistons. :D This required some modification within the block though.
        - Sean Hayes
        • luvin my 325es
          • Jul 2006
          • 45
          So basically I need to bore my eta block, get new pistons, use eta crank, rods and I will be close to 3.0L?
          I am wanting 225-250HP at the crank N/A. Somthing comparable to http://www.metricmechanic.com/ sport 3200 230HP which they sell for $8295. Is this possible or will I end up spending more on headwork, cam, maf, chip etc?
            • 34844
            I would have loved to go with the MM 3000 kit, 84mm M52b28 crank, 138mm rods, and 86mm pistons. but I'm pretty happy with my 2900 (81mm stroke, 86mm bore).
            • Eric
              • 5142
              i'm pretty new to the M20... what crank gives the 86mm stroke?
              • Sean
                • 5793
                86mm stroke is the S50 crank.
                89.6mm stroke is the S52 crank.
                - Sean Hayes
                • digger
                  • Nov 2005
                  • 6182
                  Is the stroke 86mm or 85.8mm? MM say 86 but i'm sure i have seen elsewhere 85.8 somewhere or are there two version of the 3.0L US m3
                  • Sean
                    • 5793
                    I thought it was 86 - but I really wouldn't know for sure.
                    - Sean Hayes
                    • SA E30
                      • 1248
                      I know the Euro S50B30 is 86mm
                      138mm rods ... how long that been around ? When I built my 1st stoker everybody told me I was daft 2 use them... BTW, this is on a 84mm M52B28 crank.
                      135mm rods = 1.607
                      138mm rods = 1.642
                      So IMO 135mm rods give a better rod ratio on a 84mm throw crank.
                      A mate of mine has a M54B30 crank in his M20 ... Dunno what was done 2 get that in there.
