So I just finished a full rebuild of my m20 (1989 325is M20B25). Some of you may remember my previous thread about how my old rebuilt motor failed (Still no clue on that). Anyway, everything is all back together (new block from an 87 325is) and I am ready to start it! Except when I turn the key I get no spark/fuel... (Cranks fine)
I know this has been visited many times.. and I've read many threads at this point, but to no avail.
So here are the details:
The Main Relay is working fine. It is switching power as it should.
The fuel pump relay has power to the coil side as well as the input contact side. HOWEVER, ground is never made on the coil. This is done in the DME.
So the DME is never allowing fuel to ground.
So I figured okay, one of the interlocks for start is not being satisfied. I found a helpful list of interlocks and how to check them here (3rd post):
So I tested everything in this list and it all checks out EXCEPT DME pin 48 has continuity to ground. I have a new crank position sensor and it has continuity between 2 of the 3 wires internally. My old one was like that (but it has broken a wire so idk if I trust it) Should this be the case?
I've tested all grounds and powers on the plug, diagram found here:
My DME is a 173. I also have a 152 (or 153 or whatever). There is no difference depending on which I plug in.
The DME appears to be working, if I have my DME plugged in the idle control valve actuates and buzzes away, if not this valve does nothing.
Any ideas or info on the CPS would be greatly appreciated. I'm running out of ideas.
