Replacing the alternator power line in the harness
  • Kershaw
    • 11822
    http://www.amazon.com/Grand-General-...=10+gauge+wire
    Will this work? My line is cracked and corroded, I'd like to replace it.
    AWD > RWD
  • TimeMachinE30
    • Jun 2014
    • 3749
    Have a tool to crimp 10ga?
    ACS S3 Build / Dinan 5 E34
    • Kershaw
      • 11822
      My teeth.
      edit: or should I be going with 2AWG? http://www.amazon.com/Premium-Extra-...rds=2awg+cable
      AWD > RWD
      • Kershaw
        • 11822
        Well, I ordered the 2AWG because I only had 44 minutes left on free next day shipping.
        AWD > RWD
        • Kershaw
          • 11822
          Well the 2AWG is like twice as thick. I guess it won't harm anything though. It's probably the thickness of the battery cable.
          AWD > RWD
          • Gregs///M
            • Mar 2012
            • 2459
            Dude, we make these already. We use #2 cable. It does make a noticeable difference especially when paired with a #2 engine ground. Faster engine crank speed, more stable electrical under hard load too.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Kershaw
              • 11822
              Crimped, soldered, and heat shrunk. Should be good. I actually had to solder using my MAP torch (it was barely on though) because my soldering iron couldn't effectively heat this much copper. That was interesting.
              Well that's good to know you use #2 as well. My engine strap is actually in pretty good shape. But I'm sure it wouldn't hurt to replace it as well. Might do that, thanks.
              AWD > RWD
