Injector connector pins?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    So while replacing the PCV hose, I accidentally pulled the wires out of the #4 injector connector.
    It's an AMP connector (I imagine most/all are)
    However, the Bosch EV1 style connectors on the market are typically Delphi. All I need are the pins (and some instruction on how to remove them). I would rather not replace the connector, or even worse--splice in a pigtail.
    Anyone have the part number or supplier for new pins?
  • noid
    • 1535
    Been there done that.
    Bosch 1 287 013 003.
    You're welcome.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
      • 34839
      You can get junior timer etc. pins from Amp on mouser.com.
        • Jun 2010
        • 2796
        You're welcome.
        I figured someone here had.
        Thanks!
        ETA: oh, that's the entire connector kit. Useful as I can't get the pins out of the original. Now, if only I could find gray to match...
        Ballenger is a decent source for a lot of these parts I and they even list the junior power timer pins, but I wasn't sure that's what these are.
        ETA: I'll need the entire kit if I can't get the pins to release
          • 34839
          you can get the 2-pin connectors & boots too.
          Wow those kits are expensive. you can get all those same parts from an electronics shop such as mouser. the pins are pennies each, the connectors/boots aren't even close to that much either.
            • Jun 2010
            • 2796
            CarQuest had the kit, so I was raped to the tune of $11.
            Now... which wire goes into which cavity in the connector? The pins are numbered 1 & 2 on the connector body, but the ETM (at least the one that I have) doesn't show pin numbers on the diagram.
            ETA: I just pulled the boots back on a couple of others and looked. The red/wht (+12 supply) is on the left when looking at the connector from the injector side with the wire loop at the top.
            I tried to ring out the wires from one connector to the one I replaced, but the signal looped back through the DME and both pins each showed continuity to both pins on the other. :fishslap:
