Whew! Almost broke a belt
  • Steve Corbett
    • Jul 2012
    • 449
    Was adjusting the valves on my 89 325I, Found number 1 intake had a worn cam lobe. Had a spare motor sitting in my shop. So I decide to pull that head off, rebuild it then install on my 325I. As I was disassembling it I noticed quite a bit of black rubbery dirt accumulation near the front of the motor. After I took the upper cover I saw what was causing it. Not sure how much longer this would hold up.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
  • dnguyen1963
    • Nov 2011
    • 2651
    you are one lucky dude.
    • Dagamus(NM)
      • 620
      Yep, you are lucky. I lost a motor this way. Tensioner bolt backed out.
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
      • Steve Corbett
        • Jul 2012
        • 449
        The tensioner was what let loose, The bearing is shot and barely holding together. Luck of the Irish!!
        Steve Corbett
        1983 528E Scrapped
        1983 528E Sold
        1984 745I
        1984 325E - Sold
        1989 325I Zinno
        1988 635CSI
        • Ether-D
          • Sep 2011
          • 2838
          Well, that doesn't always mean the motor is lost (kinda rarely actually). Just some valves n rockers and/or a head usually. T'was good that you found it though.
          Originally posted by Andy.B
          I was born on 3/25…
