Weird engine behavior
  • E30_Narek
    • Sep 2014
    • 398
    Hey everyone, my car's recently been acting weird and I don't really know what's causing it. Basically, on cold starts, it's idling at 700-800 RPM. If I drive the car a block, it'll drop to normal idling temperatures at about 600-650 as if the car was warm. Both temperature sensors are new so I doubt it would be this. Also, when it's warm, it will sometimes feel like there's less power than it usually has or there's a delay in the power (like if I give it half throttle of gas, it will take about a second for the car to realize this). Whenever it lacks power, the idle sounds like it's cammed (it doesn't jump up and down, just sounds like a cammed idle). My check engine light is on and the code reads 1224 which is the intake air temp sensor. I know this is in the AFM but I'm wondering if a bad IAT could cause these problems?
  • staysideways
    • Dec 2013
    • 373
    I am having the power problem
    • E30_Narek
      • Sep 2014
      • 398
      Well shit :(
      • staysideways
        • Dec 2013
        • 373
        Have you checked to clean the air filter?
        • TobyB
          • 5197
          Yeah, IAT could do that. Meter it at the ECU- the IAT itself is pretty durable, but the wires
          are no longer teenagers...
          t
          • staysideways
            • Dec 2013
            • 373
            t
            +1 mine was all ceroded on the inside cleaned it with picks and stuff, shot some do electric grease in there and good as new
            • E30_Narek
              • Sep 2014
              • 398
              I want to but I've been lazy recently. I'll try to do it soon.
              t
              Does this mean I'm going to need a new AFM? Hopefully not :/.
              • staysideways
                • Dec 2013
                • 373
                Maybe there is one on the e30 calssifieds in Facebook for 20
                • E30_Narek
                  • Sep 2014
                  • 398
                  I've looked lol no one sells that shit.
