Trying to diagnose fueling issue
  • OldSkoolGP
    • May 2016
    • 6
    So I bought my car about a month ago and it runs great apart from during startup. It takes about 10-15 seconds of cranking on a cold start before it will fire off. I usually crank for 5 seconds, wait a few seconds and start cranking again. Occasionally I think the cold start injector is spraying because I'll get a sudden fire and then to back to cranking and eventually it will sputter for a bit and start up.
    For the first minute or two of driving the engine surges and feels inconsistent. But once it's warmed up it runs great. I verified last week that the tank pump is pumping fuel during cranking. I can't verify if the car has an external fuel pump or not. It's an '87 325 with an eta, I don't see a pump under the car. I see a fuel filter and what may be an anti-drainback valve.
    I don't want to just throw money at the problem and hope I fix it. I'd like to eliminate possibilities and make an educated decision. Does anyone have an idea what could be going on?
  • OldSkoolGP
    • May 2016
    • 6
    I replaced the fuel filter and removed the damper. I also discovered that the connections for the primary fuel pump at some point were replaced with hardware store fork terminals. One wasn't even on tight as I was able to pull it off by hand. I soldered proper round lugs onto the wires, cleaned the terminals and put it all back together. I also tested the primary fuel pump off a battery and it does work. Still have the same problem. So it wasn't a clogged fuel filter.
    • OldSkoolGP
      • May 2016
      • 6
      Well, you guys are less than helpful. Guess I'll try some other forums.
      • 5Toes
        • 9836
        clean the fuel injectors. I bet they are flowing less than half what they are supposed to. MEPEH is a great place and I have used his services 4 times now great everytime
        • digger
          • Nov 2005
          • 6194
          check FPR to
          • Grackle
            • Jul 2015
            • 119
            I am having the same problem on my 325es. Car runs normal once it fires though. I know the valve is good cause I put a new factory unit in a few months ago. Car also starts fine if I have been driving it. Feels like the fuel pressure bleeds off as it sits after a few hours. You guys think the fpr could cause this?
            • TobyB
              • 5287
              OP already left.
              t
              • Grackle
                • Jul 2015
                • 119
                Well, I don't think the FPR is my problem. Car has been sitting a little over a week, I went to crank it up and it fired off immediately. If the FPR was dying it wouldn't have done that.
                • digger
                  • Nov 2005
                  • 6194
                  Injectors in good condition ?
                  • Grackle
                    • Jul 2015
                    • 119
                    I presume. I have the old 1.0 Motronic system with the extra injection module for startup. Car runs great when running, plugs looked fine last time I pulled then, etc.
