Distributor Cap
  • tcp88
    • May 2016
    • 106
    Distributor Cap
    Any recommended brands for replacement distributor caps and rotors?
    I have a 1989 automatic 325iX, just got it last week and I'm just slowly going through and replacing all the stuff I can (timing belt, water pump, so on)
    Also, any additional recommendations for things to replace on a new purchase?
  • digger
    • Nov 2005
    • 6192
    bosch or bremi
    • TobyB
      • 5287
      Bremi, here. And no Bosch wires for me, ever again.
      water hoses, if they're original, and fuel lines too. These things are getting THAT old.
      Brake fluid, at least, and hoses if they're original. Which they will be.
      ...and lots of other stuff, like your CSB and guibo if they're not in good shape...
      t
      • e30onBBSs
        • Dec 2014
        • 1347
        Air filter if it needs it and get a fuel filter with the lines
        BMW tech
        Umass Amherst
        05 wrx sti
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          Change trans fluid too
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • estoguy
            • May 2013
            • 1087
            Got Bremi when I replaced mine the first time. No issues in 150K km.
            Estoguy
            • e30onBBSs
              • Dec 2014
              • 1347
              You could test the wires too to see if it actually needs them. Simple resistance test across each length. Each value is different because the length of the wire
              BMW tech
              Umass Amherst
              05 wrx sti
