Ran m20 with no oil, now sounds terrible😳
  • dnguyen1963
    • Nov 2011
    • 2648
    You are in denial. Your engine is history. You might be able to drive the car around the block, but anything further than that will require a tow truck to bring it back home.
    • Reub_e30
      • Apr 2016
      • 145
      The engine is gone. That's it. Need another engine. Lesson learned. Check oil before you ever drive the car.
      Daily: 06 Chevy Colorado (wannabe racetruck)
      Drift/Track Car: 91 Bmw 318i 4dr
      • bangn
        • Sep 2011
        • 760
        Originally posted by hallockg806
        There's nothing I can do? I mean it drives, just not very powerful and takes a while to get into high rpms, and it's loud.
        Lubrication is a coverup by the government in order to rake in money and keep the paki's busy while we invade Iraq. You will be fine, engines probably on its period. Just keep rooting her until you wind up with blood on your cock. Only then will you know the truth.
        p.s your engine is seizing up.
        Boris - 89 E30 325i
        84- E30 323i
        • hallockg806
          • Jun 2016
          • 44
          Update
          Okay guys, I have an update about the car. Refilled it with oil and drove it around the block a little and after about 30 miles it seems to run much better!! It has basically all of its power back and doesn't sounds like a diesel truck lol. Still is a little louder than normal at around 3.5k rpm, and some odd sounds that kinda sounds like grinding at about 1.5k rpm and then it stops the noise at 2k, but it doesn't always do that. Seems to be all good!;D
          • IceWhite
            • Jan 2015
            • 945
            Originally posted by Reub_e30
            The engine is gone. That's it. Need another engine. Lesson learned. Check oil before you ever drive any other car.
            For how Long?
            1990 325i
            2004 330i Individual 6-speed
            • hallockg806
              • Jun 2016
              • 44
              Originally posted by IceWhite
              For how Long?
              Lol, I'm gonna take it to my local beemer mechanic and see why they say. I mean when I checked the oil there was little in there so it's not like it was bone dry. The very end of the dipstick had a dot of oil. :roll:
              • bangn
                • Sep 2011
                • 760
                sounds like your engine is fine and its fixed itself
                Boris - 89 E30 325i
                84- E30 323i
                • Bearmw
                  • 1323
                  Sticky?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    It WILL blow up in the near future and leave you stranded somewhere. Hope you have towing on your insurance!
                    • mrsleeve
                      • Mar 2005
                      • 16386
                      really................. WOW............
                      Ok 1st your compresion is likely fine thats the least of your worries . Your rod and main bearings are SHOT.....
                      You need to drain your oil out and look for metal fragments, I am willing to bet that it comes out looking very pearlessent with lots of fine bearing material in it. After you pull the filter cut it open and look and see how much of your bearings are in there. That diesel noise you hear is ROD KNOCK, she be junk and every foot you drive is pure borrowed time.....
                      With as hard as it is to source good running M20 power plants used now a days, I would park it sooner rather than latter, and start looking for a good running M20 variant, or start collecting rebuild parts. Bearings, rings, water pump, oil pump and pick up, master gasket kit, head bolts, timing set, for bare minimum starting point. Hope you didnt fubar your crank too badly by spinning a bearing and need a new one, or need a few new rods and pins........
                      Originally posted by Fusion
                      William Pitt-
                      • Reub_e30
                        • Apr 2016
                        • 145
                        • TobyB
                          • 5243
                          BMWs are tough. Drive it till it ventilates. It may last a long while.
                          I've taken apart a few M10's that should have grenaded, and yet they were still running.
                          Budget for an engine as soon as you can, though. Especially if you think track days are in your future.
                          t
                          • bangn
                            • Sep 2011
                            • 760
                            use this
                            Boris - 89 E30 325i
                            84- E30 323i
                            • hallockg806
                              • Jun 2016
                              • 44
                              Originally posted by Bearmw
                              Sticky?
                              Maybe a little bit of stick
                              • hallockg806
                                • Jun 2016
                                • 44
                                Originally posted by bangn
                                use this
                                For sure. I'll try it.
