Rocker Arm Shaft Removal
  • ewolfe57
    • Jun 2016
    • 29
    I'm stripping down the motor on a 325ic I have in order to rebuild the head and swap it onto my '86 eta. I got the head off last night and started breaking it down but encountered a lot of resistance when removing the intake rocker arm shaft. It even looks like it's scratching the channel it's being removed from. I paused there in order to get some more info before continuing.
    Basically what I want to know is...is that normal? How much resistance should there be? I knocked it far enough to get the first rocker out like instructions dictate, then rotated the cam til all rockers were loose. I watched some videos and it looked like tapping them out was the norm but I was concerned to say the least!
  • jeffnhiscars
    • Jun 2011
    • 6011
    Back off all th eccentrics, remove the rocker retaining clips and try to get all the rockers off the cam so there is virtually no tension. The rocker should be a firm hand push. Be careful,not to crack your rocker towers.
    Alice the Time Capsule
    • ewolfe57
      • Jun 2016
      • 29
      Based on that I'm afraid the end of the shaft may have mushroomed a little bit. Would it hurt it to grind the end down a little bit so it can more freely be removed? Am I looking at replacing the shaft?
      • digger
        • Nov 2005
        • 6199
        its fine to file off any dags so it doesnt score the bore of the head. just clean any shavings etc afterwards
        • shoup
          • Feb 2012
          • 100
          I've had some that have put up some resistance. Your head could be warped. Any overheating issues?
          1990 EE30 156V Electric Conversion
          1990 325i #610 Poor Boys Racing/FCP Euro Endurance Racer
