Radiator Connections / Coolant Fill Question
  • azndeugene
    • Sep 2013
    • 192
    Hey guys, so I did a whole timing belt and water pump change and now I'm trying to fill the system. I tore the car apart a few months ago so I have forgotten where some connections go[emoji29]
    Where does this go?
    All the coolant seems to be draining out of this "vent"
    Also, does anything connect here?
    And are both of these vents or does the radiator connect to one of these ports on the expansion tank?
    Thanks guys!
    1986 325
    1988 325is 2.7 Stroker
  • SpecM
    • Oct 2005
    • 4531
    the two nipples on the radiator and the coolant res connect together with a small dia hose
    the threaded port is for an auto trans cooler. if you have a manual trans then the port is left open with no worries
    1989 cirrisblau-metallic 325i
    • azndeugene
      • Sep 2013
      • 192
      Thanks for the info SpecM!
      One thing, I only see one nipple on the radiator (the one I took a pic of). Either way i think it should solve my problem of just spilling fluid everywhere haha
      Sent from my XT1254 using Tapatalk
      1986 325
      • uturn
        • Dec 2010
        • 1006
        The nipple on the radiator goes to the one on the reservoir with the metal insert. The other nipple on the reservoir is routed to the fender as a drain when your system over-pressurized and the cap lifts. The screws on the radiator, auto tranny oil cooling lines.
        • azndeugene
          • Sep 2013
          • 192
          Awesome, thank you for clearing that up!
          1986 325
