Replacing exhaust studs
  • KnockOffBrand
    • Feb 2014
    • 58
    So I'm in the process of changing out my exhaust studs for the manifold that go into the head, and I was reading some threads about it and some say it's crucial to chase the threads to clean them out with a tap before installing the new studs. Is this important to do? Also, when screwing the new studs in, what is the torque spec for tightening the studs? And should I apply some sort of anti-seize compound or loctite to the studs before installation?
  • Vincent Brick
    • Feb 2013
    • 879
    I feel its important to chase the threads. I only install the studs finger-tight or a little past, with a little bit of anti-seize since it is a steel stud into aluminum. I have not experienced any issues doing it this way although sometimes the stud comes out with the nut upon removing, but that seems to happen sometimes no matter what you do. I'll take one coming out with the nut over one snapping off.
    1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
    WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
    • jeffnhiscars
      • Jun 2011
      • 6011
      Do not torque these unless you want to risk cracking your head.
      Good advice from VB
      Alice the Time Capsule
      • digger
        • Nov 2005
        • 6199
        anyone remember where to get the studs with hex drive allen key at one end?
        • whodwho
          • Jun 2008
          • 1547
          I went stainless and got a set of these and hope they are up to the part for a set of these nuts, I have not installed them yet but these nuts are a work of art (well I think they will work nicely anyways... 8^)
          http://www.ebay.com/itm/x4pcs-M8-1-2...item2ee7df04b7
          http://www.ebay.com/itm/QTY-2-M8-M10...-/152083452195
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • KnockOffBrand
            • Feb 2014
            • 58
            I got studs and copper coated nuts from fcpeuro. So the consensus is that there is no certain torque spec, just hand tight? I've heard like 10-15 ft-lbs on other threads/forums.
            • Vincent Brick
              • Feb 2013
              • 879
              My recommendation is finger tight. Also try to blow any oil/chunks/etc. out of the holes after you chase the threads, before installing the new studs.
              • AndrewBird
                The Mad Scientist
                • 11898
                No reason to go any tighter than finger tight. Basically just enough to keep the stud in place.
                You don't have to chase the threads, but if there is junk in them, you should. If the studs won't go all the way in with just your fingers, you should chase the hole.
                I highly suggest you use the stock copper nuts. Keeps them from rusting onto the studs.
                • mtnbimmer
                  • May 2012
                  • 73
                  Chase the threads with a thread chaser, not a tap (yes, there is a difference and for a reason...).
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    They are surely solid copper and not coated
