Your distributor sits on that timing cover, without the engine hoist bracket, not sure if incorrect spacing will cause funny issues with contacts and the rotor.
ALMOST BLEW UP ENGINE, but how!?
I should have clarified. I meant leave out the dowel.
**BUT, after I did the timing belt job today I turned it on and it idles fine. Only when I gave it a little gas did the belts start to scream and it shut off. I gave it some time and started it back up again and it idles totally fine, and when I give it gas it doesn't die. But, the belts still squeal like crazy. What could this be? I made sure not to tighten them that much. Maybe they're too lose??
It also takes forever for it to turn over now too :(Last edited by Jdub; 07-11-2016, 04:33 PM.Comment
Update pt. 2: I got my new CPS plugged in and the car runs great again. Still having issues with the poor throttle response but overall the car feels more responsive.
I think my next step will be adjusting the throttle cable as I haven't done that yet and it seems pretty loose. Also dropping in some Lucas Oil Stabalizer to help with the slight ticking I am getting!Comment
If This is true would the bolt on the right being stripped but still sitting in place cause any problems? That bolt o mm my head is stripped but as far as I can see doesn't seem to interfere with anything. That said my valves tick like crazy.
Oh and done mean to thread jack thanksComment
I have the same issue and I have been driving it daily with no issues at all. Also just took an 1800 mile road trip with it like that. Hope that helpsIf This is true would the bolt on the right being stripped but still sitting in place cause any problems? That bolt o mm my head is stripped but as far as I can see doesn't seem to interfere with anything. That said my valves tick like crazy.
M20's tick when they are perfect. It's just what they do.
The injectors are very audible.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
